So I haven’t used my X-Carve in a long time. Plugged in a new laptop using Easel to cut a new design.
Everything appears to work fine but when starting, the Z axis tries to start about 1/4" below where it
has been aligned. X-Y are fine and Z appears to be correct after the initial 1/4" drop.
What is causing it to start cutting much deeper than expected?
Thanks Neil, im only using easel in browser. Went to machine setup from the easel navbar or menu. Did the machine steps. On the do you have a probe step, i chose yes, clicked advance, clicked default settings, clicked to run a test probe.
Exited out of wizard.
Now, i just replaced 611 router with a new one because old one started making a slight clicking noise when hand turning the collet with or without bit.
Have only ever tried setting z level using probe during carve setup. Have not tried setting z manually.
Dont know anything about the advanced stuff or device interfaces, but willing to learn.
Thanks for the reply you sent earlier. Ill reply back if the router switch was successful.
Did you set the thickness of your Z-Axis puck? Since you state that the cuts appear normal after the first step downward, I would think this is most likely a setup issue for the Z-Probe puck…
