Hello I wish to report a problem I am having and hope to find a resolution.
Machine Specs: 500x500mm X-Carve with grbl and gshield, nema 17 stepper motors
Software: Easel.
purchased: Feb 2016
material: plywood
Bit: 1/8inch 2 flute upcut.
Feedrate: 1020mm/min (40IPM)
Depth of cut: 0.7mm (0.0027")
Cut a few parts no problem, but noticed I had cut into the waste board. was unusual as I recently leveled off the wasteboard.
Cut some more parts and noticed that the first path seemed to cut deeper then my settings, I noticed this firstly by the noise. There rest of the passes seem fine, based on the noise.
I measured my parts were I hadn’t cut through all the material and noticed depth was wrong (too deep)
Ran a test cut of 1mm (0.04") deep. Cut came out at around 2mm (0.08")
Ran a test cut of 0.1mm (0.004") deep. Cut came out at around 1mm (0.04")
I ran these tests multiple times. Restarted the Machine and homed the machine a few times.
To origin the Z above the work piece I use paper under the drill bit. Accuracy of my Z origin to date has been really good.
Belts look good, I’ve checked of the bearings and nuts, tightened them if they needed to, gave it a good clean.
I Don’t think steps are wrong, has been working fine previously,
It just seems that the work Z is off. first pass cuts too deep. I thought perhaps because I use one computer to work on the drawings on easel, then a laptop to connect to the machine and run easel; it may cause some conflicts, but test cuts were new projects created with the machine connected.
Has anyone had this issue occurring before?
