Ok, So I upgraded the belts, rollers, stepper motors, ridgidity panels and Z axis on my xcarve 1000 a couple of months ago. I have been having an issue during 3d carves (most noticeable on those). I will do a roughing toolpath and it completes with no problem. I start the finishing toolpath zeroing off the surface of the material with the zprobe (have also tried manual zero of toolpath). I start the carve and seems ok for 30 or 40 minutes of a 4 hour carve. First there are lines in the carve Then i notice that the finishing bit (Amana 1/16 TBN) is not in contact with the material any longer. I stop the carve and command return to zero where i find the tip of the bit is now roughly 1/16 to 1/8" above the material. I have tried manualy zeroing from that point and restarting, I have also tried manually setting the bit .01 below zero and resetting to zero. Same issue. Some history, I have dismantled the collet and blew it out, I have tried bottoming the bit into the collet thinking maybe i was missing a slipping bit? I also measured with the calipers the bit length from tip to bottom of collet before trying a carve and after and they are the same before and after even though the bit does not end touching the material.There is a new waste board, I have ran a vbit across the x and y axis just touching the waste board and there is no visible difference between one end and the other. We have switched the x and z cables. All produce the same result. We as suspecting a bad z axis unit and have one coming under warranty. I was hoping to see if anyone else has had any issues such as this and what if any solution was found.
On the backside of Direct Drive Z Axis Upgrade, there is a coupler with some set Alen set screws.
just behind the logo, there should be no movement.
Sorry, I should have mentioned that i checked both the coupler with the nylon inserts in it and the other side with the coupler with the worm screw allen set screw. I did not get any play by moving them and the set screw was tight. I have been told also that the unit is a non serviceable part by inventables.
Just to be safe I checked the coupler again and did not find any movement. I was however able to get about 1/16 of a turn on one of the set screws. I also noticed that the coupler is down almost againt the lower part of the unit? I am not sure if I remember this being this way when i got it or not but it does not move when i loosen the set screws. I retightened them and i am testing to see if it will retain zero throughout a carve. I appreciate your response! maybe this was my issue after all. I will know in an hour or two.Here is another picture of how the coupler looks on this machine.
Update: Still no good. same issue. after running the toolpath again and returning to zero the z is 1/8" gap over the material.
I’ve read that some of the bits are metric and will not seat properly. Is it possible your bit is sliding in?
Thanks
We have tested this and the bit can reach the spoil board.
Thanks. I have replaced the collet and tried multiple bits to no avail. I have even measured with the calipers the distance from the tip of the bit to the collet before and after a carve and it is not moving
I did notice that if i manually move the coupler, i can move it between 1/4 and 1/2" before there is any movement of the tip of the bit. This does not seem normal as i dont think there should be any play there. How is the worm shaft attached behind the router plate? does anyone know?
Here is a short video that shows what im trying to say:
it is attached with a delrin block… here’s the old assembly manual for the old version Z axis, I believe the delrin block part is the same in the current Z axis…
I’m experiencing a very similar issue with a recent 3D carve attempt and have also made the same adjustments and completed the same inspections. It just doesn’t make any sense and just feels like it’s more of a programming issue instead of a hardware issue. I could be very wrong as I am still new to the CNC world but I wanted to join the conversation and let you know you’re not alone.
SOLVED:
I replaced the Z Axis unit with a replacement from inventables. Problem solved.
