I have had it with my Xcarve 1000. Seems issues come one after another, I did get alot of info thru the Inventables Forum but I was not going to be the guy that continued to have issues every time I did a cut. I did have a few successfull cuts but then another issue would come up, I have ordered a completely different machine (OneFinity journeyman pro) as the new Xcarve Pro is way over priced. I do want to understand the issue and figure out the solution to my latest problem.
I bought a new Z probe from Inventables, I set it up in the machine settings, When I went to probe for my roughing pass It was able to probe successfully, But for the final pass the z probe would not pass the CONTACT portion of the process which resulted in my router pushing down onto my z probe and not stopping which caused me to shut the machine off which I have never been able to get my Zero position to line up after the machine cuts off. What pushed me over the edge is this happened 2 times back to back resulting in wasting 2 seperate 3 hours roughing cuts.
