I have set up my machine (Sainsmart 3018 PROVer V2) and the z probe works in the initial setup.
The probe has also never failed in other programs and the machine is new.
I set up my first project in Easel and went into the Carve mode, walked through the steps, but when I got to the material depth and select Probe, there is no progress and the probe is not recognized contacting the bit.
I had to go back and do a manual paper depth position since the probe function failed.
(If you are curious, I am making blood spatter angle boards for our forensics labs!)
you can go into machine inspector by pressing ctrl+Shift+D and seeing if there is an alarm to indicate the probe fault cause.
Also if you go to Machine>Edit Machine there’s a button to edit the probe settings at the lower left, that might hold some information as to the issue as well…
