Hello everyone, I’ve been a long time original X-carve user and have recently upgraded my machine.
Approx 6 months ago, I started having issues with the depth of cut on my machine so decided to buy the upgrade kit. After the upgrade I ensured my grbl settings were correct and completed a series of test carves within easel to check the depth of cut. I set the depth to 0.125" and they all came out at 0.135". I reinstalled my machine, and checked the thickness of my Z-probe. Using calipers, my Z-probe is 0.590". In the set up, the Z-probe default is 0.590". I tried to cheat the machine and set the z-probe thickness to 0.600". This resulted in 0.145" depths - the opposite direction!. When setting up a new machine, I noticed all of my xyz axis were backwards. I reinstalled a new machine, but this time, I set my z-probe thickness to 0.580" thinking maybe this too was backwards. Voila! It cut at 0.125"
Using calipers, I tested a 1" movement in the z-axis and it came out to exactly 1" on the nose.
I went to bed happy last night that I got that resolved. This morning I fired up the xcarve and I was back to 0.135" depth of cuts!
Re-installing the machine with a z-probe thickness of 0.580" yielded 0.125" depth of cuts again. Why am I having to ‘cheat’ the machine into cutting the correct depth of cut? This is with the new z-axis.
My second issue was discovered today - I ran another test carve in Easel - a 1" square. It came out to a dimension of 0.985" x 0.985". How do I resolve this cutting issue?
Here are my grbl settings -
- ok
- $132=152.500
- $131=750.000
- $130=750.000
- $122=50.000
- $121=500.000
- $120=500.000
- $112=2000.000
- $111=8000.000
- $110=8000.000
- $102=49.909
- $101=26.660
- $100=26.660
- $32=0
- $31=0
- $30=1
- $27=1.000
- $26=250
- $25=750.000
- $24=25.000
- $23=3
- $22=1
- $21=0
- $20=0
- $13=0
- $12=0.002
- $11=0.020
- $10=115
- $6=0
- $5=0
- $4=0
- $3=0
- $2=0
- $1=255
- $0=10
- ok
- [OPT:VMP+,15,128]
- [VER:1.1g.20170629-Inventables:]
Thanks for any input anyone might have!
Rob
