Hi,
When mounting the z rod, it is not vertical… (Rod is, but bearing seems to hold it not vertical )
Problem is when adjusting the wheels , the tension is different at bottom then at top.
What to do?
I can put high tension on the tiling belt, but I think that’s to much for the stepper.
Many thanks,
Bart
update:
did some lubricant on the rod, reversed the derlin nut and searched for the correct belt tension and it’s much better now.
I will mount my dewalt 611 router later, and see what happens.
