I have an object that at i would like to cut with a 1/4 bit but later cut with a 1/8 bit only on certain lines. Is there any way to tell it to not cut a certain object?
Set the objects you do not want to cut to 0
Oh yeah I guess that would make sense , thank you
you know what, i’d never thought of that. I’ve been making copies of the file, then deleting the bits i wanted to cut in different bits. So i’d end up for loads of copies cluttering up my easel project list.
I’ll give that a try next time.
Thanks.
There are a lot of little tricks you can do with Easel. I have been making a few short videos on the basics.
