Now that we have an easy way to create files that have hundreds or thousands of vectors it would be nice to be able to turn off the automatic saves. I was just cleaning up a vector image and each time I made a tiny change Easel stopped responding for about 45 seconds while it saved the image.
If I could turn off auto save while I was making adjustments and turn it back on again that would be great. Or just let the user save the file when we need to save it.
That probably isn’t actually the saving-s fault. It says “Saving…” when you change something, but really it just waits patiently until you have stopped making changes and then saves, the actual “save” only takes a fraction of a second.
I believe that the real problem probably lies in what we call the “accurate preview”. That is when we take the gcode (well, a simplified version) that would be generated and simulate it onto the 3D preview. It can take some time with complex designs. We have been working on ways to make the process faster and smarter about when to run. I’ll keep you updated on it.
I’m sorry I know that can be very frustrating with a large design.
I just ran a quick test - with about 900 vectors, deleting one vector takes about 14 seconds with the material being shown and about 12 seconds with the material hidden. So it is a bit quicker but still seems like a long time when making lots of edits.
I am not complaining, it is still way better than doing the vector work in Inkscape.
The vectorization app is amazing, and you developy-types should be pretty darn proud of yourselves. I haven’t carved any of the designs out yet, but I was actually shocked at how fast and (in a computer brain sense) intuitive the app is. It really does a bang up job. If we could export the results as an SVG (hint, hint ) I’d be able to use the same files to cut some wicked decals on my vinyl machine too, and save myself an inordinate amount of design time and frustration with other software.
Here is how it turned out. Used a 1/32 bit .02 per pass total cut depth of .04 on white pine. Stained and then sanded the surface to lighten it a bit. The size is about 4x5 Doing this on a tighter grain wood would really help.
Paul, Easel is Awesome, Can I have access to these early APPS, i have been working with easel pretty exclusively, love the ability to work from anywhere. Just got off the phone with a great guy at inventables… Thanks for everything.
I would definitely love to see the V carving in easel!! I am working on my X-CARVE workstation right now that I plan on putting in some V bit text, if that comes out soon I can use easel and post up the video mentioning all the features coming into easel! But I’m hoping to get to the text in the next couple days and as of right now I’m using V Carve Pro!!
Got to try this today in 0.5mm sheet copper. Took a simple skull silhouette image from the 'net and used the tool to produce the design. Then copy and paste to make another. Each skull is 40mm x 40mm.
Cut with a 1/16th fishtail at 10,000rpm, 0.1mm depth step and 120 mm/min feed (still trying to find a good balance between speed and finish).
Very lightly finished and hand hammered for pattern. Will be properly cleaned and polished tomorrow. One will become a necklace pendant.
Tool works really well and is a great way to get shapes into Easel quickly, ideal for jewellery making, wife thinks it’s magic.
