I found assembly instructions, but I cannot find any video or information on how to use the X-Carve. I have very limited experience with any CNC machines to begin with, but I am used to programs like LinuxCNC and Mach3. Can those be used with the Arduino controller? Any help/tips would be great! Thanks
Hi @DerekTombrello the Drunken Woodworker just posted a tutorial. Also Bob from I Like To Make Stuff posted a cool tutorial on Easel.
@DerekTombrello The Arduino is used in lieu of Mach3 or LinuxCNC.
The Easel method is very easy and basically walks you through the whole process.
The other method is to use a CAM program to generate the tool paths then send them to to the Arduino using a âsenderâ program like Universal GCode Sender. That is a very similar experience to using Mach3.
@Zach_Kaplan Thank you⌠I will watch those this weekend.
@BartDring Iâm relly not a big fan of âcloudâ computing. I like to keep my hardware and software on MY end if the cloud Iâll look into the GCode Sender. Thank you, too!
