I wonder is there a knife bit that could cut and make a smooth edge which would have to swivel I guess like on my vinyl cutter machine. Just wonder has anyone cut cardboard?
Would be faster then using a laser cutter if there is a way. I’m not cutting real small things.
get a drag knife these are what you need for cutting cardboard on the machine
If you can justify hundreds of dollars for this, that’s your ticket.
no kidding.
it is expensive but worth the hassle and it will pay for itself if you have the work for it
Just out of curiosity what type of work would use this? Does that thing cut vinyl to?
that knife will cut
cardboard
vinyl
wood
plastic
foam
rubber
cork
leather
paper
etc
hands
fingers
toes
etc
I feel a DIY project coming on.
http://www.cnczone.com/forums/general-other-machine-discussion/205452-cnc-software.html
Thanks for the ideas on the drag knife.
I cut coroplast. Nothing too intricate, but it works really nice, and 4’ x 8’ sheets are about 15 bucks.
For cardboard, I would say use a compression bit if you can, for smooth edges. As long as it’s not really small stuff, you should be fine. Try it - whats the worst that could happen? You might waste some scrap cardboard…
You could make one if you have access to a 3d printer:
http://www.thingiverse.com/thing:1761794
http://www.thingiverse.com/thing:1307494
http://www.thingiverse.com/thing:731270
