We are pleased to announce the new machine controls entering the Beta program. The new controls improve the flow of the machine jogging, allow for easier homing and let you do repeat carves. To enable the controls enroll in Beta program now by visiting the Options tab in the Account modal and making sure you are enrolled in Beta.
To enable Repeat Carving after enrolling in Beta visit the General Settings where you can check the box to show the shorter walkthrough next time you carve with no changes in your design.
With repeat carving, can I resume a carve that I stopped? In other words, I notice a problem and hit “X” to stop the carve. I fix the problem, and so far, I have had to put new material on board and start over rather than just resume the carve. Or is there already a way to resume a carve that I have not seen yet?
You can only resume a carve from a paused state at current… not once the carve has been ended.
you could manually edit the gcode file, or start it from the top and increase the feed to speed through the previously carved portion, .making sure to slow it back down b4 it carves Into new material.
