New to easel. I have an Openbuilds Leed + Blackbox.
The carving is bigger that what I ask Easel to do.
I set my material to desire size (16 x 7 inches) and design my carving inside of it. I “HOME” the machine to the left bottom corner. I put a mesuring tape under my router and JOG 1 inch. The result is 1.25 inch. So it seem to be 25% bigger.
You need to recalculate GRBL parameters $100 (X) and $101 (Y) and possibly $102 (Z) aswell.
To list your current parameters open Easel Machine Inspector and in the Console window type $$ and press Enter. A list will appear showing each parameter ($0-$134)
If your current $100 and $101 value for instance is “100” this mean that your X/Y stepper must do 100 steps to move 1mm. But you get 1.25mm for 100steps.
Math is:
Step per mm divided by actual distance * commanded distance
100 / 1,25 x 1 = 80
To change the GRBL value type in Console $100=80 and press Enter
Do the same for Y, $101=80
Reset controller.
Test actual travel vs commanded travel. Once settled you can fine-tune this value if required.
