Has anyone made or have plans for a simple vacuum table
for the x-carve? Need to be able to hold down Dollar Tree
foam-boards to carve.
If not, looking for ideas…Thanks
IIRC someone posted about pocketing the wasteboard and then creating an insert with holes that could be used, or swapped out with a solid piece…
Do a search on vacuum table using the mag glass in the upper right corner.
Try this … 12x12 vacuum table
