Do I need a zip wire?
I purchased a DeWalt DWP611 for my X-Carve 1000mm and am unclear as to whether I need a zip wire or not? Can anyone clarify this for me?
Thanks.
You may find good information on following dicsussion.
Hi,
Thanks for the response.
The assembly instructions for the wiring section say:
If you purchased a 24V or 48V spindle with your X-Carve kit now is a good time to attach the zip wire that will eventually power it. Pull the black and red wires away from each other and strip the ends leaving about 1/4” bare. Wire them into the bottom of the terminal block in the two spaces you left open. Use the left terminal for red and the right terminal for black.
I looked at the documentation that came with the DWP611 and did not see a reference to whether it is a 24 or 48v machine?
Thanks again.
U don’t need zip wire however if u plan to add a laser later on, u could run wire and tuck away . It can be used for that.
