You click on the “outline” button on the “cut” panel and select the corresponding setting:
Easel is designed to automatically carve inner shapes before outer shapes. Can you provide a link to your project if this is not what you are experiencing?
Has anyone found a work around for importing dxf with closed paths? Everytime I import from using solidworks the imported path isn’t closed and increases my cut time by retracing cut paths.
Hi Rene, can you post your solidworks part file? If that’s to difficult maybe just the dxf. I will have a look at it. But it can take me some time since I’m not home at the moment
I exported a dxf from fusion360 as a step file, then used another turbocad to generate a dxf, but easel is having an issue with a SVG, so under the covers must be a conversion to svg going on. DisplayBoard v4.dxf (580.3 KB)
Any pointers would be good
I tried to open your DXF in inkscape as well as some online convertors and they all came up empty. I think something went wrong with the conversion of fusion 360 to turbocad. I opened your DXF with solidworks and it seems it is still a 3D object. I took the liberty to save it for you as a regular DXF:
I have tried both of these with the same result. They are generated by another program for making halftone images. It might be something with how it creates the DXF.
Trying to download the attached DXF. The file tries to load but nothing happens. IT is 668kb in size. Please help.20toothsprocketcombo (1).dxf (668.3 KB)
