edit. found my answer. reading helps
I found the issue being when i clip one end of the circuit to the router whilst plugged in(but not on obviously), it causes the issue, so to solve, i just donât have any power to the router at all until I am zeroed.
One question can you explain the differences between reference tool and measure tool?
Before you start machining you use âreference toolâ for the first tool, then âmeasure toolâ after each tool change.
some people mentioned that Estlcam takes several minutes to load large CNC files.
Iâve found the issue and uploaded an update: www.estlcam.com (Version 8.212)
It should now be able to load even very large files within a few seconds.
I have a wired Problem with Estlcam USB controller. The patterns Estlcam carve to small. When I want to carve a 50mmx50mm sqaure, Estlcam carves a square with roughly 40x40mm.
The generatet G-Code from Estlcam ist fine. I can send it UGS and my X-Carve works fine with a 50x50mm sqaure.
My Setup is:
- Arduino GRBL PWM
All axis same values: - Steps per revolution: 1600
- Travel per revoluztion: 40mm
- max feed reate: 5000mm/min
Any ideas?
Thanks!
BG Michael
Hi,
I think for the X-Carve it is 36mm for X and Y (Z has other values depending on the thread used).
Christian
sorry for my late replay.
Christian, can you explain how the 36 are calculated for X and Y?
If have Nema17 motors on my X-Carve with the Pulley 26054-01
It has 20 Teeth.
Further more the X-Carve uses the GT2 belt with 2mm Pitch 26053-01
So 2x20 = 40?
Thank for your help!
BG Michael
For the 20 teeth pulley 40mm would be theoretically correct.
Whatâs the configuration youâve used for UGS?
By the way: there is a new update resolving a glitch which caused small dents in some toolpaths.
to be honest, I didnât do any custom settings in UGS
You can solve it this way:
Letâs assume youâve set 1600 steps / rev and 40mm distance / rev at the moment:
- First letâs check the steps / rev settingâŚ
- Enter âX40â in the controllers command line (see below) and see how far the motor turnsâŚ
- It should turn exactly one revolution - not more - not lessâŚ
- If it is more than one revolution the setting is too high, if it is less than one the setting ist too low (typical values are 400 / 800 / 1600 / 3200)âŚ
- Once steps / rev is correct check the distance / rev settingâŚ
- Place a ruler under the tool, enter âX100â and see how far the machine actually traveledâŚ
- The correct setting for steps / rev will be old steps per revolution * (distance traveled / distance entered)
- Example: You entered X100, the machine traveled 80mm and the old distance / rev setting is 40mm you get 40*(80/100) = 32mm per revolution.
Hi!
Just been testing Estlcam with my X-carve, must say it looks very promising - might start using this also to control my my machine!
I have however not tuned it yet, but getting close on
X Y Z
1600 1600 3600
40 40 20
If somebody tries this out an tune it (for an X-carve with ACME z-screw) I would love if you share your results here - will do the same myself.
Estlcam is a fantastic package for the price with possibilities that Easel is not even close to deliver - however it is not a CAD.
Great job @ChristianKnull - hope you will continue to expand the functionality of the software. Would love to have a âwhatâs upâ section to know what we can expect in future releases.
Brgds
Christian
Yep. Loving Estlcam. I havenât done a full switch for using it as a machine controller, but Iâve run a lot of jobs with it already.
Okey I have fine tuned Z with Estlcam - Steps per rev 3600 - distance per rev 19âŚit is spot on with ACME lead screw.
I find 1600/40 to be perfect on X and Y - Arduino is set up with 8x microstep.
When it comes to max feedrate I am running 2000mm/sec on X and Y and 1000mm/sec on ZâŚmaybe abit conservative?
The cool thing is that it is so fast to switch from Estlcam to Easel - since Estlcam has a restore function it makes it a Easel/grbl machine in 3-4 seconds
Now it is time to do some 3D carving!
Brgds
Christian
Thank you Christian for your support.
I did a reset on ESTLCAM and startet again.
My Settings are:
X: 1600 / 40mm / max. feedrate: 4000mm/min
Y: 1600 / 40mm / 4000 mm/min
Z: 1600 / 5mm / 1000 mm/min with a M8 threaded rod from my local hardware store
This setting work fine for me!
I am still not sure about the maximum feed rates. Any suggestions on that?
BG Michael
I canât remember my values, but the easy way to set them is to say start at 8000, then use the controller to move the axis at the fastest. Chances are it will stall. Lower the value and try again. I would drop down by 1000, until it works fine, then up by 500. I think I was able to do about 5000 for X and Y and 750 for Z
Finding reliable feed and acceleration settings is explained here from 2:43 to 4:33:
- Basically you start at a low feedrate, apply the change and see what happens if you move the axis at full speed by clicking the corresponding arrow in the controller window at its maximum speed position.
- If it works well increase the value and try againâŚ
- If the axis stalls go back to the last working value and further decrease it by a 20-30% safety margin. This is important otherwise your machine will not be reliable because any minor issue may cause step losses.
If you want even better settings make a series of tests also with different acceleration distances:
- Change the acceleration value, repeat the above test and note the final feed rate settings.
- Youâll notice that fast acceleration (low acceleration distance values) limits the achievable feed rate.
- If you plot it as a X / Y diagram youâll also notice an area where further increasing acceleration distance wonât improve speed anymore.
- Finally you have to find a compromise between feed and acceleration - I usually prefer a setting where the machine achieves about 80% of its maximum speed to avoid compromising acceleration too much.
- For things like picture engravings where you have thousands of short moves with constant accelerations I optimize for extreme acceleration settings as the machine wonât reach maximum feeds at the short distances anyway. This can cut machining times down to a fraction of the time youâd need with a more traditional setting.
I just added a auto leveling / surface scan feature with version 8.301:
It allows to engrave curved surfaces or compensate uneven machine beds - e.g. for PCB milling.
@ChristianKnull this new mapping feature has me sold on your software. My only hesitation is this: Iâve upgraded to the Xcontroller. Without the Arduino/Gshield configuration that was originally shipped, will Estlcam still work with the new hardware?
Not sure if it was there before, but I just noticed the Update Drawing command. Very cool.
I donât know too much about the X-Controller - but as it runs GRBL it should be compatible unless there are some fancy modifications to the hardware or bootloader.
If someone gives it a try please let me know.
