Here is the “Baby Boy Photo” that comes with the trial of PhotoVcarve… I need to figure out the technique for contrasting, paint a dark color then sand, but I feel that the carving is to shallow…
One technique that works is putting a clear sealer on a piece of wood without a lot of contrast. Run the PVC file, then apply a stain to darken the areas that get carved to most, which are the darker areas of the image. Keep in mind that PVC works basically on a halftone process for simple photos. You can adjust for greater or lesser depth, but I haven’t played with that too much.
I used UGS for this… I still haven’t tested PicEngrave Pro 5… I need to figure some other stuff out first… I started having a few issues with the x and y axis stuttering… I think there is to much dust getting on the extrusions, so i have been cutting out a dust shoe; however, I was able to get some paint on the carving though…
It isnt terrible, but i dont think it is great either…
That looks like the result I got from photoVcarve in wood. I was never satisfied with how they came out so I gave up on trying to make pictures in wood. My next attempts will be to cut lithophanes in candlestone.
Folks have done some great looking things with PVC. When you read their techniques, one thing that stands out to me is that they file the tip off an engraving bit to give it some “body”. That, and setting the stepover seem to be how they succeed. I’ve done some testing with the techniques I’ve read there and it works pretty good but I haven’t spent much time on it - too many other things of greater interest to me up until now.
woa !!!
I finally managed to test the demo picengrave
it was a compatibility issue.
to install your software on Windows 10.
must start in compatibility mode Windows 8
the app looks really good
I am only two small test with small images.
i will try bigger one ^^
@picengravertoo there is a preview of the engraving in picengrave or picsender?
I could not try picsender cause my xcarve is not yet mounted =/
and badly the gcode created by your software isnt compatible with G-code sending through easel
We determined the best preview to use is to view the original color image in grayscale. Picengrave calculates the depths of cut by 8bit (256) shades and that is the purpose of the “View Gray Scale” selection in the image editor and the main program. Black is the deepest cut and white is the shallowest, unless your engraving a Lithophane, then it’s reversed.
Previewing a raster gcode file with short incremental & stepover toolpath moves, really does not show much. It looks like this, so it’s best just to judge the outcome from the grayscale preview of your image.
Our programs generate gcode by the standard formats that grbl and other CNC controllers require for compatibility. Easel will not run the standard range of G & M code format for grbl compatibility, so it’s best to use another gcode streamer that will.
I am using the trial version of picsender and the $h button works fine but I cannot jog machine to set my 0,0,0,postion. the Y+ and X+ are green and I have a value i the box but machine will not move.
There may not be a default jog feedrate set in the grbl startup block. Click the $N View Startup Blocks button and it should display the startup blocks $N0=G20 for inch units or $N0=G21 for Metric units in the message window. Right below it is for setting the default jog feedrate and it should show $N1=FXX. XX will be the default jog feedrate. These settings load each time PicSender connects to the com port & grbl and you can add them by executing those commands in the Do Cmd window and button… You can also set the jog feedrate after connecting with the Fx dropdown menu and button.
I redid the photo again, this time with a 1/4 ball nose (waiting on the 1/8 bit to come in)… I think it came out way better than before… Pardon the finishing technique as I was just trying to see if I could get the contrast…
