Is there any way to fix Z if you want to change bits
I have a tendency to move the Z axis when I have to change bits.
Is there any way to avoid it
Are you holding the router with one hand when you change your bit?
βAre you holding the router with one hand when you change your bit?β
Normaly yes, but I could not do that earlier ,
but now I can move it both forward and back while the x-controler is still on
This is in one of the links above. It can be done without taking the whole x controller apart, although you have to open it up a bit to get to the boards. You should be able to change bits while the motors are locked in position as the torque is higher with the switches off.
https://sites.google.com/view/x-carve-noob-essentials/idle-torque-settings
