Another Vote for OpenBuilds Control as the CNC Controller. Best CNC Software is OPENBUILDS CONTROL - Cool Features - YouTube
However just so you’re aware, the paid Pro part of Easel is only the design side, you could continue to use Easel Basic (non-pro) to send the Fusion360 gcode files to the cnc after your Pro account expires and converts back to Basic.
It is recommended to home the machine before each use, especially with the X-Carve Pro seeing that it has a self squaring feature built in that only works when the machine is homed.
(Technically the term is Gcode Sender Software because. GRBL is the firmware that’s on the CNC, and the gcode sender does need to be grbl compatible, but kinda semantics, but wanted to clarify the term usage there)
IF “Use Last” isn’t working than the gantry was moved manually (by hand) between the 2 carve jobs.
IF you home before the first, and then again before the 2nd than the “Use Last” will be spot on.
That said, other gcode senders, like openbuilds, have built in “JIG Position” functions where the user can home the machine, move to a known position and save it as a semi-permanently (until saved over) position. This is useful when using a L fence OR when other Jig’s are used from time to time on the CNC but always registered to the exact same position. (2 positions can be easily used, and another 2 can be setup manually, but those extra 2 are a bit more complicated to setup, the default 2 are VERY simple within OpenBuilds as there are already buttons for setting the position and then for using the position(s) later on)
Well, Easel Pro only effects the CAD/CAM portion of the process, so IF you’re already using Fusion360 for the CAD/CAM than there’s not really ANY benefit with using Easel as the sender other than familiarity with the layout.
Not at all.
Yes, Set $21=1 this will allow those limit switches to function as true physical limits.
The steps to see the current settings and to get to the page to make this change are here: X-Carve PRO Default Grbl Settings 2021 – His N Hers Handcrafted
you will need to send this command to change this setting:
$21=1
NOW I should mention there is ONE issue currently that might stop you from being able to use OpenBuilds Control with your specific model CNC.
During an update in early 2022 Inventables pushed a new grbl firmware to Xcarve Pro users through Easel. This update changed the machine’s Baud Rate from 115,200 (the grbl standard) to 5,600, which I suspect was either an error or for some reason having to do with Xcarve Pro having occasional data packet drops… Well OpenBuilds Control only works with 115,200 Baud rate, so you might be able to simply go into the USB port settings and change it to 115,200 OR you may need to call inventables and have them provide you with the last prior firmware which allows it to still run at 115,200 and then it’ll work with OpenBuilds Control like every other Grbl cnc. At least a handful of other Xcarve Pro users have reached out to Inventables support to have this issue corrected so that they can use OpenBuilds Control…
