Hi Seth, yes, I setup the (standard Z) probe and thickness.
And set XYZ for $130, $131 and $132.
OB is sending G91 G21 X1000 FNaN - and that last one seems to trigger an error.
FNaN = function not available N?
These are my settings, maybe someone sees an issue:
Grbl 1.1f [‘$’ for help]
[15:11:06] [ ] Grbl for ARM32
[15:11:06] [ ] Version:ARM32 V2.1
[15:11:06] [ ] $0=10 (step pulse,usec) ;Step pulse time, microseconds
[15:11:06] [ ] $1=25 (step idle delay,msec) ;Step idle delay, milliseconds
[15:11:06] [ ] $2=0 (stepport invert mask) ;Step pulse invert, mask
[15:11:06] [ ] $3=2 (dirport invert mask) ;Step direction invert, mask
[15:11:06] [ ] $4=0 (stepenable invert,bool) ;Invert step enable pin, boolean
[15:11:06] [ ] $5=1 (lims pin invert,bool) ;Invert limit pins, boolean/mask
[15:11:06] [ ] $6=1 (probe pin invert,bool) ;Invert probe pin, boolean
[15:11:06] [ ] $10=115 (status report mask) ;Status report options, mask
[15:11:06] [ ] $11=0.010 (junction deviation) ;Junction deviation, millimeters
[15:11:06] [ ] $12=0.002 (arc tolerance,mm) ;Arc tolerance, millimeters
[15:11:06] [ ] $13=0 (report inches,bool) ;Report in inches, boolean
[15:11:06] [ ] $20=0 (soft limits,bool) ;Soft limits enable, boolean
[15:11:06] [ ] $21=1 (hard limits,bool) ;Hard limits enable, boolean
[15:11:06] [ ] $22=1 (home cycle,bool) ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
[15:11:06] [ ] $23=3 (homing dir invert mask) ;Homing direction invert, mask
[15:11:06] [ ] $24=100.000 (homing feed,mm/min) ;Homing locate feed rate, mm/min
[15:11:06] [ ] $25=500.000 (homing seek,mm/min) ;Homing search seek rate, mm/min
[15:11:06] [ ] $26=250 (homing debounce,msec) ;Homing switch debounce delay, milliseconds
[15:11:06] [ ] $27=2.000 (homing pull-off,mm) ;Homing switch pull-off distance, millimeters
[15:11:06] [ ] $30=10000 (maximum spindle speed,rpm) ;Maximum spindle speed, RPM
[15:11:06] [ ] $31=0 (minimum spindle speed,rpm) ;Minimum spindle speed, RPM
[15:11:06] [ ] $32=0 (laser mode enable,bool) ;Laser-mode enable, boolean
[15:11:06] [ ] $100=800.000 (x axis pulse:step/mm) ;X-axis steps per millimeter
[15:11:06] [ ] $101=800.000 (y axis pulse:step/mm) ;Y-axis steps per millimeter
[15:11:06] [ ] $102=800.000 (z axis pulse:step/mm) ;Z-axis steps per millimeter
[15:11:06] [ ] $110=2000.000 (x axis max rata:mm/min) ;X-axis maximum rate, mm/min
[15:11:06] [ ] $111=2000.000 (y axis max rata:mm/min) ;Y-axis maximum rate, mm/min
[15:11:06] [ ] $112=2000.000 (z axis max rata:mm/min) ;Z-axis maximum rate, mm/min
[15:11:06] [ ] $120=50.000 (x axis acceleration:mm/s^2) ;X-axis acceleration, mm/sec^2
[15:11:06] [ ] $121=50.000 (y axis acceleration:mm/s^2) ;Y-axis acceleration, mm/sec^2
[15:11:06] [ ] $122=50.000 (z axis acceleration:mm/s^2) ;Z-axis acceleration, mm/sec^2
[15:11:06] [ ] $130=290.000 (x aixs max travel:mm) ;X-axis maximum travel, millimeters
[15:11:06] [ ] $131=180.000 (y aixs max travel:mm) ;Y-axis maximum travel, millimeters
[15:11:06] [ ] $132=40.000 (z aixs max travel:mm) ;Z-axis maximum travel, millimeters
It is a SainSmart Genmitsu 3018-PROVer V2.
BTW: not wanting to hijack this thread, if I should start a new one then let me know.
