I’m getting this error
I’m saved it from vcarve pro post processor xcarve(inch)
I don’t use Easel but I remember people taking about the fact that arcs ( G2 and G3) can be a problem and that converting to straight line segments is the way to go. I know in CamBam there is a setting to do that.
Again, I’m not sure about Easel at all.
I don’t understand programming. Doesn’t support arc? Have no idea what that is… but with that being said is there a work around to send this to the machine without using easel?
Well you can download the universal gcode sender and use that. I use the classic stable version on a laptop.
See how your software is set up compared to this:
