On the x-carve control board are two extra wiring ports: Spindle PWM and Spindle (1-10V).
I understand that these ports allow for controlling the spindle speed, but I’m not sure how to properly connect them to the Huanyang HY01D511B VFD and could use some direction on the proper wiring.
I think I’m supposed to use the 1-10V on the x-carve to the VFD, but I don’t know where to connect the the +/- leads to on the VFD.
Here is what I’m trying to figure out. The positive (+) seems obvious to hookup, but I can’t figure out where to plug in the negative (-) wire. The manual is problematic with either poorly translated Chinese or referencing unfamiliar industry jargon/acronyms. I don’t want to make a mistake and fry the VFD.
I’ve got the same table in my manual. I was thinking the negative needed to go to either ACM or DCM, and I tried them but nothing happened.
When I read through that thread you linked, if I understand correctly, it looks like the ground should be connected to ACM. Maybe I’m not correctly changing the appropriate parameters on the VFD to respond to the signals from the x-controller.
Just had a chance to try out the VI/ACM hookup and it didn’t work.
After connecting the wires, I went into Easel, set the machine for automatic spindle, and tried to turn the spindle on and off but it didn’t do anything. I pressed “RUN” on the VFD and tried again, but same results. Also gave the manual another reading through and I don’t see any parameter adjustments to activate/deactivate the spindle speed, or change the speed control from the pot to the VI/ACM inputs.
I do. Set it to DCV and 20V, touched to the X-Controller output for Spindle 0-10V and when I was setting up the spindle settings in Easel for automatic control, the output was reading 5.85V.
Ok, so you are getting an output signal from the X-controller that should activate the spindle and you have the control signal hooked to the correct inputs on the VFD (VI/ACM), the only thing left is the internal setup of the VFD.
I’ve taken you as far as I can. Someone else will have to pick it up from here.
Actually @LarryM, there might be some advice you could give. You seem adept at reading those electrical diagrams, maybe you can take a second look at that VR input.
I see it says 10V/5V, and I read a reference in the CNCZone thread (@ErikJenkins linked earlier) that was advising the OP to make sure VR, VI, and ACM were hooked up.
Just got me wondering if the PWM from the x-controller could connect to the VR … maybe that 10V/5V reference in the diagram means it can be switched between 10V and 5V … and it’s supposed to be some kind of activation that has to triggered before the VI signal can be used?
Take a look at the snippet from the manual in the diagram above. The VR+10V/5V is an output from the VFD which is used in conjunction with the potentiometer to generate the 0 - 10 volt control signal.
You can verify this by taking your voltmeter and testing the voltage between VR and ACM without anything being wired to the VR terminal. You should read approximately 10 volts with the VFD turned on.
Since the X-controller already generates the 0 - 10 volt signal then you don’t need the VR output.
