I will get the shop vac for now and after I get back to the states I will invest in a dust collector.
Seriously? Burn your house down. Duty cycle isnât the amount of time it takes for an appliance to catch on fire. Not following manufacturers guidelines will make the likelihood of component failure higher. The overheating increases wear. There is thermal fuse that will shut your wet dry vac down long before fire anyway.
I cant speak to what was wrong with your shop vac. But I can tell you that it wasnât from running it with disregard for the duty cycle.[quote=âDouglasSchafer, post:51, topic:32816â]
[/quote]
Iâm not even sure what that is supposed to mean, maybe an attempt to be condescending. Either way not necessary. so lets just agree to disagree.
Maybe that wasnât the best way to start a postâŚI apologize. Seriously .I just didnât agree with this statement. [quote=âPhilJohnson, post:47, topic:32816â]
You are risking fire hazard by not adhering to the specifications. Count yourself lucky if you violate it on a regular basis and havenât burned down your house or garage.
[/quote]
I also I felt that was directed at me and I took offence. I should have just let it go.
Sorry to revive an old thread, but I thought it better than starting a new one just for this questionâŚ
I got my suck it installed-ish last night, and Iâm seriously disappointed with the acrylic endcaps that mount the slide rails to the carriage. I donât feel like I torqued them very hard at all, and they were even still able to wiggle, yet one of the threaded inserts immediately started spinning with the screw before it was ever even tight, and another one just popped right out. Iâm going to hit up Suck-It and see if theyâll replace the two end caps.
But it did make me wonder, has anyone else simply drilled through the rails and carriage, tapped the holes in the carriage, countersunk the ones in the rails, and attached the rails directly to the carriage without the end caps? Anyone think it would be a bad idea?
Thatâs exactly what I did when I got my new Z slide.
One small screw on top and one on the bottom.
When I upgraded to my Z axis (not the newbies one), I made an adapter plate with threaded holes to secure the T track to. Works perfectly.
Thatâs a definite upside, too.
