Hi everyone.
I’m interested in cutting large foam sculptures, and as I’m using slices, would like to use 2" foam.
Does anyone know if there is enough clearance on the X-Carve?
Also, this bit that Inventables sells is 2,1/4"
https://www.inventables.com/technologies/solid-carbide-2-flute-foam-cutter
How much of the endmill needs to be in the collet? Does anyone have any leads to longer end mills?
Thanks for any suggestions on max depth and appropriate cutting tools.
