Hi,
I am making a small box with a base of 4 sides with 45degree edges and the walls each having 3 sides with 45 degree edges. The plan is to glue and use two brad nails to make the box once it’s cut. The top of the box will have a slight indentation where a sheet of 1/8in ABS sheet plastic will be the lid. The base and 2 sides each have cutouts, and screw holes.
I am making two worksheets in one project one to that has the 1/8in end mill cuts and one that has the 90degree v bit cuts. I’ll run the end mill first then the v bit.
Is there a better way?
Thanks for your thoughts!
James
bigbot.pdf (181.7 KB)
