Yeah! that’s awesome, much more sense.
Can’t wait to hear about the 4th axis project, I have that and laser on my short-list for this fall, hoping to learn from your mistakes
I am sure I will have some, it should be fun
I am going with the ethernet solution…I’ll keep you posted.
I’ll get some pictures posted tomorrow…but yes, 3-jaw chuck.
where?
most info I found suggests it won’t work. But most ofthat info was
a few years old…
You can’t just use a USB to parallel printer converter, it won’t work. Instead you need a USB adapter that has a suitable Mach3/4 driver i.e. Smoothstepper or UC-100
pff another piece of hardware to add to the tally and another 100+ bucks… And it doesn’t support Mach3-Lathe
I think I’ll just find me a scrapped PC with parallel port and be done with it.
An add on, PCI parallel port card will only set you back about $30. As long as it supports ECP/EPP, it will work fine with Mach 3 (or Linuxcnc)
Playing around a bit with the rotary axis…for this I simply swapped the Y-Axis connector for the rotary axis connector. I needed to adjust the mm per step also. I’ll be making a mount for the head and tail of the rotary axis so they simply bolt to the wasteboard holes.
Here is a quick v-carve on a dowel. Nothing spectacular, but a good start. This is still using grbl.
Nicely done! great idea to swap A for Y as a Proof of Concept, can’t wait to see more.
I have far too many projects to tear apart my machine for things like this right now, so I’m going to be watching your progress intently, thanks for sharing !
Thanks, the nice things is, I used 4 pin XLR connectors for the motors, so it only takes a few seconds to change everything back.
I think there is a belt and pulleys on that box behind. You can play with them to find perfect movement with Y axis power without changing any steps on grbl. Mitsumi usa have calculation tool for it. I’m not familiar with but I’m sure you can figure that out.
I justed wanted to make sure everything worked. I also did a small relief carve to run the rotary axis for about 30 minutes, everything worked great. Once my new electronics show up, I will be departing from grbl and going with the gecko g540 controller and Mach4.
Here is the relief carving on the same dowel, again the steps are off so the buffalo is a little squashed, but I was just testing things out.
Wow, very impressive. I can see this being used to make precision dowels, wands for Halloween, and a dozen more things.
Do you think there’s any way to trick Easel into doing this? Maybe “unrolling” the carve surface into a rectangle so it thinks the Y axis is moving instead of the rotary? It wouldn’t be able to spin all the way around so it would take longer, but maybe it would work…
Right now the way I am doing this, grbl thinks I have a regular 3 axis machine. You would have to adjust the steps per mm for the Y-Axis and do a mirrored image; the Y movement on the rotary makes the carving backwards. For the text, I had to design it mirrored for it to come out correctly.
Easel can do the flip and rotate no problem. Now I’m REALLY interested in this, can’t wait to see what you make with it.
Probably, but since I am changing electronics I won’t go that route.
man I check in on your thread every so often and you have some cool stuff going I took the pluge and bought a 4x8 machine but I am looking at a 4th axis like yours also
here is a pic of my new machine
Wow, that is a beast!
