sexy sexy lol I am really feeling spoiled check out the tread I just started to watch some videos
Another test with the rotary axisâŚI tweaked the steps per mm and it is spot on now. This is still using grbl:
A 1.125" diameter dowel, I used just a 0.25" ballnose bit on this. A single spiral.
Pretty damn cool. Out of curiosity, how big was the steps per mm adjustment, and howâd you calculate it? Was it trial and error or did you wrap a ruler around the rod and calculate from there?
HIMMM. I donât have 4th axis upgrade, but I upgrade my system with MiniCAT 2016 system. The problem is I canât run the machine.
just install Idog, that should sort it out
It looks like you really splurged and got the multiple redundant MinCAT system.
Carve some mice and send them to the other side of the shop
For the steps per mm, It was a little trial and error and a little math :-).
The diameter of the dowel was 1.125 inches I multiplied that by 3.14159 (pi) to get the circumference of the dowel, 3.534 inches.
I made a mark at the bit location, told the machine to move 3.534 inches to rotate the radial axis, if correct the axis should rotate 1 full turn and stop on the mark. I adjusted from there.
When I replace the electronics, once everything arrives, the calculations will be translated to degrees of movement for the axis, so I will have to play around with settings again.
But it is fun
Time to kit it up! I am definately doing this once the cold, cruel Minnesota winter sets in. Next week.
Erik- you are really on to something here! Well done. I can only hope that you will share your notes on the conversions you did to make it work. Amazing.
I have to guess that the upgrades @ErikJenkins did to his Z axis (and X axis height?) are almost a necessity to make the 4th Axis work, unless the rotation A axis somehow happens to fit under the stock XCarve Z axisâŚ
I knew I wanted a rotary axis, that was the primary reason for the X and Z-Axis height increase.
Here is a small piece of cherry from a tree I cut down last year. Next time Iâll use a larger bit, but with a 1/4" endmill it only took about 30 minutes to make a nice round cylinder to carve.
Now you need 4th Axis dust control ahh, life is roughâŚ
Here is one problem with using a rotary axis with grblâŚeach time a different size cylinder of wood is cut, the steps per mm must be adjusted to match that particular piece of wood, not a huge problem, but just adds a bit of time to a project. Once I get the new electronics installed, it wonât be an issue as true rotary axis support moves the axis by degrees and not linear movement.
Not a show stopper, just something to consider if anyone plans on going this route and staying with grbl.
Iâve done quite a bit of lathe work, so being covered with sawdust is like an old comfy blanket
@ErikJenkins - meant to ask, what font did you use for the scrabble letters and numbers? Iâve been playing with creating tiles but I just canât seem to find the right looking font. Not sure if itâs just the display, but they just donât seem correct to my eyeâŚ
I used News-Gothic.
thanks, Iâll try it.
Here is that piece of cherry from my yard with a relief carve.
The models are from Design and Make, I used a 1/8" endmill to rough and a 0.5mm radius tapered ballnose to finish with a 17% stepover.
I also noticed that it was 1 year ago today that I built my X-Carve and did my first carve. My machine has changed a bit during this last year, but I am enjoying using it more and more each day. I want to thank @Zach_Kaplan and everyone at Inventables for such a great product, the best customer service I have had the pleasure of experiencing and the most helpful community around.
Now, back to making sawdust!
