Hi all,
It’s my first post, please be gentle, how do i do joined up lettering ie family so it can be milled in one complete piece.
TIA
Dal
Hi all,
TIA
Dal
To join letters or objects set all to same cut depth and pocket carve (fill), choose them all, then select Combine.
You now have one combined object you can set to cut outside of path.
You can also search for “Monogram” here which will yield relevant hits
Brilliant, thank you for your help…
Where would I find the combine button, stupid question i Know but I just can’t find it.
When using Easel go to EDIT then down to COMBINE
You have to have at least 2 objects selected or when you go to EDIT you will not see the COMBINE tab.
This will help you along the way
