Monogram / Door Hanger / Fatten Type
I get a lot of questions on how to do this, see pictures below.
Fatten Type
You can use the Offsetter app to Fatten type. After you fatten it select all and fill. Then you will need to set the areas to either full depth or zero depth and then re-combine
1
Remember once you set your outline you can control it somewhat on how it cuts by choosing, inside, outside or on path. Tabs are your friend with these I use one to two of them in every waste area.
IMG_3262
IMG_3263
IMG_3264
IMG_3265
IMG_3266
IMG_3267
IMG_3269
IMG_3270
IMG_3271
IMG_3272
IMG_3273
IMG_3274
IMG_3275
IMG_3276
@Chen1
@BrianArnold
Anyone know what Font the M is he is using
Purchased the set off Etsy for a couple of bucks 2 years ago.
