How can you make a single row of text in easel
Trying to make this.
Thank you,
Shawn
Create your sentence or phrase, then rotate 90 degrees and use the tiling feature.
Tiling instruction is in link below
simply select the “T” icon on the left and select the desired font.
Once a font is selected a text box appears with the word “Text” entered as default. Select this and delete the default “Text” word and write your own message.
IF the sign is so LONG that it will not fit along the X axis and you need to implement tiling, you can do as Mark indicated.
