Amazing!!!
How about some red LEDâs for his eyes?
Iâm sure I glazed over many comments on this threadâŚI was too excited to see the final product!
Impressive build Mr. @PhilJohnson very impressive. Maybe we need to lower the price of the X-Controller to compete with you.
No it takes about 20 minutes.
The best part, of course, yourâs has a life-time warrantee!
Your lifetime! Iâm always confused: life of the machine, the company that sold it, or you.
Ours is a county fairgrounds gaurded by the neighborâs cows. The cows dont care who you are, what you find or what you do with it.
Phil, what company do you work for, if you donât mind me asking? Electric mining shovel caught my eye. I worked for CAT until mid September of last year in underground longwall mining.
Can you get me a picture of the switch settings on the x or y TB6600 driver?
Since your 6600s are set for stepping arenât you double stepping would you set your arduino to 1x just a thought.
HMM but if you micro step the shield and then send that signal to 6600 arenât you double stepping.Iâm sure Larry can figure this out.
What I was going to try to verify is that you have correctly identified which direction of the switch is ON and which direction is OFF.
(BTW- I donât have mine hooked up to a machine yet so I canât just run it to verify the settings)
Yeah, I have to use a magnifying glass to see that the arrow beside ON is pointing toward the heat sink.
Check your current too.
Have you checked the motor current?
âŚand hang it on the wall?
That should be a safe value for the motors. So the Y will benefit from 1.5A for TWO motors to 2.5A for EACH motor, no wonder you sense the difference.
Quite a fast build too when you consider all the extra stuff you created.
I see looking at schematic that I was way off as the 6600âs are replacing the Arduino Shield
Great work Phil!! Iâll have to start laying out mine and add the VFD in the mix as well.
jer
I put gt3x6mm belts on my X axis it it looks like it will more than do the job for my two X(B) carriages. Iâve been sliding them back and forth many many times(without them wired up) and it works great. In fact, I dontâ know why inventables donât switch over to them and get rid of the gt2s. It wouldnât cost them anything to do so and it will be a much better set up, especially since everbodyâs going the Linear Z route any way.
