I want buy x-crave .i take dewolt or makita . My english not good
If you can choose (similar availability and price) get the Makita due to lower minimum RPM than the Dewalt.
Put two wraps of Gorilla duct tape around the Makita. Tight and secure in the Dewalt mount that came with the machine
I used pop cans for shims. Works perfect. Took 4 of them for my spindle.
And now the Shapeoko adapter is gone.
Instead of the adapter a suitable length of suitably sized aluminum tubing works well — the Imperial size (2.75") is a bit thin walled, but metric in 70mm has a 2mm thick wall and seems to work well once cut to length and a slot is machined into it.
What kind of adapter?
I have created a mount for a Hitachi router. I can make one for this Makita is anyone is interested.
All I require is the footprint and the mount you are using if its not from inventables.
