Materials to Carve
Your stock answer on materials says “various plastics”. I’m presently using ABS very successfully, however, I want to use acrylic, which is very brittle. Any advice?
Yes. Search these forums; lots of folks cut acrylic all the time with great results.
Hi - thanks for posting. Easel will give you some default baseline settings for working with acrylic. As Traxxtar mentioned there is quite a bit of information about working with acrylic on the forum. Here are a few links to get you started:
https://discuss.inventables.com/t/acrylic-cutting/33078/8
