Is it reasonable to assume that the rotational axis is at one extreme, which would allow for someone to do 2 dimensional cuts in the rest of the cutting area?
Yes and no.
You could easily use the gshield to drive it but your would have to re-calculate your steps per mm the specific project diameter every time.
It would be better to upgrade to something like the TinyG, which supports degrees per step.
I have one and it works very similarly to gshiled / grbl, just a lot more configuration options. Of course you would not be able to use it with easel, but you would not for rotational carves anyway.
This gives me dangerous idea to build a stand alone spindle carving machine, it wouldn’t need much more room than a typical wood lathe and be capable of so much more. Kind of like a legacy ornamental lathe on steroids…
You can set the rotary axis on one edge and use the rest of the machine. My rotary is bolted to maple boards with holes matching the wasteboard holes. I can move mine to anyplace on the wasteboard and attach it.
Very Nice!!!
It is too bad that you do not sell a “kit”.
This ‘super simple’ 4th axis looks interesting also-
I actually looked at that one before I went the way I did. It looks very cool.
Eric, the rotaty is obviously a 4th axis but because xcarve already has 4 motors and you added a 5th, in theory your machine is actually a 5 axis correct?
My controller is set up as a 5 axis machine. I slave 2 of the drivers together for the Y-Axis.
This forum thread is potentially unhealthy for my wallet.
Here is the rotary axis rounding a 3" x 3" x 6" hunk of walnut to a cylinder. I used a cheap 3/4" bit which was not quite flat on the bottom (new Freud bit on order) which is why there is a spiral line running down the finished piece. The spiral is not a big deal as I will be carving this piece.
The piece was not quite square when I started and I had to add a few more passes to bring the cylinder to 2.85" diameter when it was finished.
Total milling time was just over 20 minutes. I could have gone faster, but I am still getting used to the settings.
I sped most of the video up to 3x speed.
Thank you for posting the video, you have built a very impressive machine!
I would be scared to death that the big 3/4 bit was going to hit the mounting plate when it gets to the left end of the cylinder.
I left an 1/8th inch for buffer
What are you going to carve with the new rounded block?
That will be the next video
I created the toolpath with CNC Wrapper. You are right about a lot of air cutting, I could speed it up quite a bit, but I’ll wait until I get a better bit…should be here Monday.
20 min for rounding this… very nice I was guessing stuff like this takes hours !
Yes but you would have to have someone program it to convert the distance into rotational Axis info.
Yah… like a CAM program maybe?
That skull - that doesn’t look rotary wrapped… what SW did you do it in and how did you send it to the mill?
