Need Help with a "sign"
I have a request for a friends wedding. They want a style like MR&MRS on top of their last name, but the letters are cutout and connected as one piece. So it’s not a sign per se, but the letters are cut-out from the wood, but still connected from parts of the edge of the serif font. And because she is needy, they then want it to fit like a jigsaw. Is this even possible?
Have you thought about just doing the stacked text. This is very easy in Easel.
Can you give us a better idea of how it is to be laid out? I have an idea of what you are talking about, but I just want to make sure before I do any work on it. Maybe a hand-drawn image?
{:0)
Brandon Parker
Yes. What do you have so far?
but the last name is Schwisow…
This should help, same principles
Something like this?
I think the OP also wants puzzle piece cuts between the letters (or words) so that they come apart like a puzzle as well … At least that how I understood it. If you share that file, I can update it to add that.
{:0)
Brandon Parker
YESSSSSSSSSSSSS! That’s what i am looking for. And then somehow making it a jigsaw puzzle as well. The point of it is that each guest will sign a piece, and when it is all together, it will show the above picture.
@BrandonR_Parker
If each guest is going to sign a piece that will be a lot of little pieces.
They might have to rethink the puzzle pieces
EDIT: If they use the Justice of the Peace and 2 witnesses then 3 pieces will be good :flushed: :grinning: :joy: :joy:
Awesome…looks like everything is good to go then …
{:0)
Brandon Parker
Thank you all, i will attempt the cut tonight. very special thanks to Mr. Crawford, it is extremely appreciated!!
Why not a inlay ?
