Not following path when carving using pocket function
Hi,
I have problem with easel not folloing path when carving pocket. First run is OK, but half way thru secund run the x jumps 3,5 cm. See picture. I have tighten all screevs etc. Any idea what I do wrong?
Most likely lost steps, most likely due to machine not able to carve effectively the feed/depth rate you are at.
If the bit is sharp, go less deep.
GShield or X-controller?
I use the GShield. I will try with less feeding speed.
here is a tutorial on how to set the current limits X-Carve Maintenance/Troubleshooting Videos - Add Your Own! - #4 by RobertA_Rieke
Thanks :slight_smile:
Try shallower depth per pass before slowing down feed rate.
With the gshield unless you have already will benefit from being adjusted to correct current limit for the motors. I suspect they are being powered below their optimum limit. Underpowered = more easily steps lost.
