Thank you
@GlennMDutcher @DavidMalmarowski @GeekDad63 @DoxCoach599 @JackE_Lodder @LucianDChapar @ToddTreece @GrantFlude You all have access!
Can I have access?
Hi Eric, can you give me access? Thanks!
I use Fusion360 and would love to be a part of the test group!
Hi my x-carve hasnt arrived but im using vectric aspire and would love to send the g-code through Easel may I try this aswell
Thankyou Eric!!
Thank you Eric!
Hi i am using meshcam and will love to try this new feature
Sign me up please
Please and Thank You. I’d love to get in on this as well.
thank you Eric, greatly appreciated
Hi there can i please have access to this?
Thanks frank
Just a small question before carving
the gcode is just x-y-z command?
and the feedspeed (or movement speed of xcarve) is regulated by easel right?
dont want to destroy my machine xD
Thanks!
(i use fusion… Just to know if i need to put right speed in fusion or in easel…)
I’m just getting started so I’d like to hear confirmation on this, but I believe that basically none of the settings in Easel (speed, stock size/thickness, bit size) matter when you’re just importing existing G-Code - since all of those factors are baked into the G-Code Easel doesn’t really do anything with them.
[quote=“StevePrior, post:615, topic:17483”]
[/quote] @RaphaelPascual @StevePrior Correct. We are currently working on changing walkthrough to let you know that these settings don’t apply to the imported gcode, and will remove those steps from the walkthrough.
