I’ve purchased a C-Beam Linear Actuator (250mm version of http://openbuildspartstore.com/c-beam-linear-actuator-bundle/ ) with the intention of using it as my new Z-Axis.
Does anyone have experience with doing this? I have a few questions…
how to best attached linear actuator to X-Axis?
use Openbuilds motor mount (I have DW611 router) or use mount from X-Carve?
any other issues to watch out for or suggestions?
Any advice, pictures or videos much appreciated.
Thanks, I have assembled the linear actuator already. I’m looking for advice about how to attach it to the X-Carve.
B.F
November 12, 2016, 1:45pm
#4
I just finished my X-Carve build and I attempted using the calibration project in EASEL and the carve wentthrough my 1/2" MDF board and another 3/8" into my waste board.
Do I calibrate the Z-Axis with or without material?
I am a newbie at CNC.
should be simple to attached C-beam to the X Carriage Extrusion.
using the 4 screws and T-Slot Nuts then Spindle Mount to C-beam plate.
Can someone post pics of their completed X-Carve with C-Beem please.
For those that have tried this linear actuator setup, does it add more stiffness to the z axis? I’m considering upgrading to this to eliminate some of the slop of the original setup, I like the idea of the ACME screw being fixed on both ends.
Thanks!
What did you end up with for setting on your $102? I’m current stepping about 2 inch for every .5 of an inch I ask the Z axis to move.
KrisCrawford:
2 inch for every .5
Divide your current steps ($102 setting) by 4. Then measure more precisely and recalculate until you have it dialed in.
