Ordered this week!
Cannot wait to get my machine in. Just ordered a 500x500 and will be using it for some wood carving, PCB prototyping, and God only knows what else! I’ve wanted a machine for many years.
The active forums, and the seemingly great support from the company is why I chose to go with the X Carve.
In the mean time, I think I’ll need to come up with a work area before the machine comes in!
Welcome to the family!
Welcome, same boat here…lots of youtube how-tos to watch!
I’m waiting for the new Dewalt spindle mount to come in before I order the 1000mm. Can’t wait :bowling::alarm_clock:
You can see some of the work areas other have built in this link. There are some amazing ideas here!
Welcome to the club! I have a youtube channel with a bunch of x-carve projects, diy wasteboard and a workstation! Check it out when you have a chance…https://www.youtube.com/channel/UC06V_T_wsAl8Pt5OatvSkzg
@JeneJohnson I was waiting for the 611 mount too but could not take it anymore and placed my order tonight! Figured when it comes out I can hopefully add it to my order but at least have a place in line since it sounds like the dates are starting to slide a little bit.
I was thinking about that too. After viewing my cart. Do you feel that there is anything I’m leaving out? Thanks for your time.
X-Carve
X-Carve Core Components
X-Carve 1000mm Rail Kit
Black MakerSlide, support extrusions, GT2 belts, brackets and hardware
X-Carve ACME Lead Screw Kit
ACME lead screw and Delrin nut
X-Carve 1000mm Waste Board Kit
Waste board with threaded inserts and hardware (clamps not included)
X-Carve NEMA 23 Stepper Motor Kit
Four 140oz-in stepper motors, pulleys, hardware
X-Carve 300W 24VDC Spindle Kit
24V 300W spindle, custom mount, cap, wrenches, hardware
X-Carve Arduino/gShield Motion Controller Kit
Arduino, gShield, enclosure, fan, USB cable, wire, hardware
X-Carve Power Supply Kit
24V / 16.7A / 400W Power supply, interface PCB, power cord and hardware
X-Carve 1000mm Wiring Kit
Cable, terminal blocks, hardware
X-Carve 1000mm Drag Chain Kit
Drag chain, mounting brackets, hardware
X-Carve Limit Switch Kit
Switches, wire and hardware
X-Carve Tool Kit
10 tools for assembly, including a T25 Torx driver, various wrenches and safety glasses, all in a durable pouch
X-Carve Clamp Set
Secure material to the waste board while carving
X-Carve End Mill Starter Set
Five 1/8" shank milling bits with 1/32", 1/16" and 1/8" cutting diameters
X-Carve Digital Calipers
Measure the exact thickness of the material you’re carving
V Carve Pro
CAM Software - $174 machine bundle discount (reg. price: $699)
Orders placed today ship within 3-4 weeks $1,823.50 $1,823.50
remove ER11-A Collets, Nuts and Wrenches ER11-A Collets, Nuts and Wrenches
30415-01
Description: ER11-A Collet, Shank Dia.: 1/8in (3.175mm), Type: Collets & Nuts
$6.65 $6.65
30415-02
Description: ER11-A Collet, Shank Dia.: 4.5mm, Type: Collets & Nuts
$6.65 $6.65
30415-03
Description: ER11-A Collet, Shank Dia.: 1/4in (6.35mm), Type: Collets & Nuts
$5.84 $5.84
30415-05
Description: ER11 Collet Wrench Set, Shank Dia.: n/a (Wrench set only, no collets included), Type: Collets & Nuts
$5.00 $5.00
30415-04
Description: ER-11 Collet Nut, Shank Dia.: n/a (Collet Nut only, no wrenches or collets included), Type: Collets & Nuts
$5.84 $5.84
remove Solder Sleeves Solder Sleeves
30515-01
Size: 26-24awg, Glue Color: White, Qty: 50
$13.85 $13.85
30515-02
Size: 22-18awg, Glue Color: Red, Qty: 50
$15.85 $15.85
remove Carbide V Bit Carbide V Bit
30342-01
Shank Diameter: 1/4 in, Cutting Diameter: 1/2 in, Tip Angle: 90 Degree, Type: V Bits, Cutting Length: 0.36 in, Overall Length: 1.8 in
$13.50 $13.50
30342-02
Shank Diameter: 1/4 in, Cutting Diameter: 1/2 in, Tip Angle: 60 Degree, Type: V Bits, Cutting Length: 0.5 in, Overall Length: 2.07 in
I really like your work bench. How did you find the foot print of the 1000mm? I too would like to be able to build mine be for my x-carve gets here.
