Installed Creators update and it if I click Carve it just repeatedly forces the Driver installation popup window.
CARVEY. LATEST VERSION OF EASEL.
Was working fine before the update.
Have uninstalled/reinstalled >3 times.
Hard power off & reboot all machines
Disconnected plugs from both Ports, laptop & carvey
Tried different Port on USB
Tried Chrome and Edge
Running check.bat automatically closes the command prompt within seconds. No error message displayed.
No data at all ln error log.
It is zero bytes and I cannot attach it.
Same problem here after the creator update. Have tried re-installing the drivers, removing device, scanning for hardware changes etc. Stange thing is, that Carvey shows as device when checking installed printers. So the USB connection seems to be working, but Easel does not see the machine. Tried Universal G-code sender too, but no joy. Any suggestions? My other CNC machines running on MACH 4 work fine after the update.
Hi @RobbieMacgillivray, @NicoBerx, and anyone else having Easel repeatedly tell you you need to install the driver after installing the Windows 10 Creators Update—
We’ve released a new version that fixes the installation problems on this version of Windows. Please go to Easel - Downloads and download version 0.3.5 (or newer, for anyone from the future).
worked fine on win 10 before update. tried everything no luck. I have a Cron Craft machine, Lightburn works fine so does candle. Easel is wasting my time
The above thread is 6 years old (April 2017) and the other thread you posted to yesterday was 3+ years old…
You may want to post into this thread that centers around the Feb 2023 Driver update:
Or start a brand new thread for your specific issue. However if you want input from Inventables then I suggest the linked thread or calling their support phone number.
