I have had to carve scores of similar items, and I have devised a simple way to zero multiple pieces -
I set up my work with a .002 deep dot just slightly larger that the bit. Such as .130 for a .125 bit with the center of this dot on x and y zero.
Then my carved pattern is slightly positive of this x-y mark.
If I need to do a recarve or touchup, I simply align the piece to a true horizontal and vertical on the waste board, and then set my bit on the z dot, and I am ready to go!!
Hope This Helps,
Martin
Wouldn’t a bump stop be easier?
I am not familiar with the term bump stop?
Please define?
Thanks
Martin
Thank you.
The advantage with my system, is that the piece not be rectangular or even all the same size. Only the one reference point is needed to get a repeatable pattern.
I will post a picture later.
God Bless,
Martin
