I’m trying to cut some deep parts and there isn’t an option in Easel to cut an outer perimeter over one bit width, so I created gcode in JSCut, and manually added the carvey specific start/end code. It’s 30MB
I’m running off a Compute Stick (32-bit) so I can’t use Chilipeppr (too much memory used with my 30MB gcode)
I can’t load the gcode into Easel and run it because IE reloads the page, firefox is too slow, and chrome crashes.
I can’t use Universal Gcode Sender (worst name ever) because the hello message is gCarvin 1.1.5. ( Source code to gCarvin/grbl? ran into other issues )
What should I do?
