I’m posting just to ask if people would please share projects they’ve completed in which they carved very fine detail with the X-carve? And please include bit types/sizes, feed rate, depth of cut per pass, material, etc…
I’ve been struggling to do some very small carves with very fine detail and I’m hoping maybe seeing some examples of successful projects would help me figure out how to improve my detail carves.
Take a look at paw paw’s projects. I use a 1/32 bit for almost everything. The two stage carving is done with a 1/4 bit. The box was done with a 1/8 bit. On some of the first project I used a 1/16 bit. I only use easel and Inkscape for software an I have had my machine for a few months
When carving hard woods like Wenge, Padauk and Bloodwood, I use a feed speed of no more than 40 ipm. I have time to spare, so I usually don’t use another bit to rough out the flats. .125 doc with a 25% stepover to rough, then .0625 doc with a 4% stepover to finish.
The pocketing of the portion of the inlay only takes 10 minutes or so, but the carve for the male portions can take 6 to 8 hours depending on the amount of detail involved.
I used 2 bits and 2 passes
1 first pass was a 1/32 end mill 2 flute up cut (inventables with white collar)
2 nd pass was a tapered ball nose bit .5mm
I do not recall the cut settings but I will check my files to retrieve it later and post them.
@StephenCook: As the link you provided takes me to a page that lists a lot of collet adapters, it is not clear to me which collet adapter you were using. Please advise.
I also couldn’t seem to find the other sellers with the 1/8" collet that would hold the 0.5mm bit? And I’m wondering. I HAVE the collet from Inventables that lets me hold their 0.02" engraving bit (0.02" is approximately 0.5mm). So I’m wondering if that collet is sufficient?
Not done with a X-Carve, but here is one of my fine detail projects.
This Lithophane was made from a scanned glass negative that I inverted positive and edited/cleaned up in Corel Photo Paint. I roughed it out with a 1/8" BEM, then cut it with a 1/32" BEM. I made the finish cut with a 1/64" (.0156") BEM to achieve the very file detail. This Lithophane is 7-1/2" wide by 5" high and it took 34 hours total time to cut it in Corian.
The Large D is the outer diameter of the collet and the d is the diameter of the inner portion.
What you want is to match up the two with the bit. 4mm on the “d” and 1/4 on the “D”
So you can use this one:
Which will allow you to use the 1/4" collet on the router to match up with the collet adaptor that matches the bit which is 4mm in diameter.
To answer you 2nd question:
I know I have seen somewhere there were 1/8" shank bits with small sizes… Just forgot where.
Also it depends on what your doing. If your doing something 4" to larger in diameter then I would say it would be sufficient. Its the details you want to achieve that determines the bit sizes. I am doing stuff almost the size of a 50 cent piece so I have to have tiny bits.
