Tiling on the X axis?
I have a BobsCNC Evolution 4, and Easel has been great. i have tiled on easel before the feature came out and it worked good. I haven’t been on my machine in a couple of months and saw the tile feature is only capable down the length of the Y axis. Is there any way Inventables can give the user control of X or Y axis tiling?
Easel pro since September 2020,
Jared
Why would tiling along the X-axis be of any use? :slight_smile:
The machine is open front/back which make tiling along Y relative to the machine the best option.
How about rotating the design 90deg?
Or set the machine up in a traditional way.
I have a bobscnc evolution 4, the x and y are opposite. Anyone know how to reconfigure the wiring and the cache to work in easel with tiling?
@JaredStovern Did you read the thread I linked to above?
To swap over X&Y you simply need to connect the X-stepper wires to the Y-output and vice versa for Y.
I didn’t realize that was a link! Just got done reading it. I will definitely refer to that, thank you Neil!!
