Quite easy to accomplish in F360, similar but slightly different approach than what BrianSaban posted earlier:
Method is basically:
- create your rectangle, extrude this whatever thickness you want.
- In Sculpt-mode create Plane covering the top surface of your stock
- Edit vertexes and/or lines to resemble the shape (topography) you want
- In Model mode choose Modify-Replace Face (optional, delete the part of the Sculpt plane outside stock)
That is basically it (sans the text in my example)
Video, with errors:
Would v carve be able to do this?
WW - here is a quick run-down on how to use F360 to accomplish similar shape.
You are ready for CAM/tool setup after these quick, simple steps.
I still dont understand how to get this wavy look. does anyone have a better video or better instructions. If im even successful with making this wavy rectangle then what. Do i import the file into aspire? model it from there???help
What software are you using?
This is awesome. Followed this method of yours which was quick and easy . However I’m having a hard time creating the tool paths for it. Anyway you can help me figure this out?
What’s your other idea? Idk how to use fusion and I want to make the 3d flags
