Phil,
what was that USB cable that you mentioned somewhere?
Do you have a link?
I want to order one just to rule it out.
Yeah, that’s the same PP I posted.
And remember to use BLUE LOCTITE!
Sorry that I’ve been away so long. (had an emergency)
Well on Phils recommendation, I ordered a new USB cable.
It should be here this week.
I also started up the machine yesterday afternoon and tried to cut something again.
When I clicked the send button the machine took off in the exact opposite direction and wiped out a clamp screw.
So now I’m wondering, would it behoove me to completely uninstall UGS and then reinstall it?
Well, to be honest, I thought afterword if maybe I didn’t properly reset the zeros.
It is a file that I have been using regularly to make signs for a brewery.
So it has already been used quite a few times already.
So right now I’m going to blame it on myself.
It does however still freeze up on me.
I’m first going to wait to install my new USB cable before doing anything else.
What has the USB cord have to do with it anyway?
What is it that’s happening?
My whole system was new in October.
The USB port is the communications path from Easel (or any of the G-code senders) to grbl. If for some reason the USB connection fails then grbl cannot receive commands and the system appears to be hung, or the communication gets garbled and grbl gets a bogus command.
There are many reasons that a USB port can lose connection. One of them is a bad or inferior USB cable.
So that’s interesting.
On the first page where it lists sources of interference, in all 3 scenarios a relay is listed.
Does that mean the IOT relay (which my USB cable lays next to) could be the culprit?
If you have the IoT relay, don’t use the Inventables power supply board. Wire the PWM signal and ground straight to the IoT relay.
There are issues with turn on characteristics with a standalone SSR that are not present in the IoT relay. It is specifically designed to take in a logic level signal.
I have no idea what all that means.
I have the new machine with the X controller.
Oops. Never mind. My comment is for the older Arduino/gShield. You should be fine with the X-controller.
No, I haven’t seen it yet.
It should be here this week though.
I’m anxious to see if it makes a difference.
Well, my new USB cable came today.
Same thing, UGS stops at the end of a carve.
Then I have to completely shut it down and restart it again.
I don’t know,very frustrating.
When the carve is complete, the machine goes back to XYZ zero.
At that point it may or it may not freeze.
Yes, I will post the file that I was cutting last night.
It won’t be until this evening though.
Without reading the whole thread , this sure sounds like you have soft limits set.
I don’t know anything about soft limits, what they are for, or how they are set.
Yes, I have the new 750 machine with the X controller and an IOT relay that controls the router (on and off)
an the dust collector.
Re-flashing??? I don’t even have a clue as to what that means.
Please remember, I didn’t know the first thing about CNC or programming before last September when I ordered may machine.
So its been a very steep learning curve for me.
I do not use Easel at all.
I use vectric desktop and UGS
Do you mean I should use the easel post processor?
Or easel for the design?
This is the first file that I ran after installing the new USB cable.
G17
G20
G0Z0.5000
G0X0.0000Y0.0000S16000M3
“M3”
G0X6.4980Y2.0315Z0.2000
G1Z-0.0443F10.0
G1X6.4994Y2.0439Z-0.0432F60.0
G1X6.5352Y2.2253Z-0.0429
G1X6.5520Y2.2398Z-0.0292
G1X6.5577Y2.2439Z-0.0252
G1X6.5647Y2.2471Z-0.0222
G1X6.5720Y2.2482Z-0.0212
G1X6.6202Y2.2479Z-0.0215
G1X6.6519Y2.2469Z-0.0225
G1X6.6879Y2.2442Z-0.0252
G1X6.7071Y2.2412Z-0.0283
G1X6.7195Y2.2380Z-0.0314
G1X6.7337Y2.2329Z-0.0366
G1X6.7363Y2.2187Z-0.0298
G1X6.7371Y2.2053Z-0.0250
G1X6.7360Y2.1902Z-0.0216
G1X6.7336Y2.1768Z-0.0199
G1X6.7206Y2.1657Z-0.0088
G1X6.7417Y2.1657Z-0.0088
G1X6.7716Y2.2607Z-0.0088
G1X6.6196Y2.2479Z-0.0215
G1X6.5717Y2.2482Z-0.0212
G1X6.5239Y2.2369Z-0.0306
G1X6.5183Y2.2410Z-0.0261
G1X6.5098Y2.2448Z-0.0216
G1X6.5019Y2.2456Z-0.0199
G1X6.4805Y2.2437Z-0.0190
G1X6.4535Y2.2390Z-0.0185
G1X6.4290Y2.2320Z-0.0190
G1X6.4071Y2.2229Z-0.0201
G1X6.3877Y2.2118Z-0.0219
G1X6.3712Y2.1996Z-0.0238
G1X6.3571Y2.1861Z-0.0259
G1X6.3454Y2.1714Z-0.0282
G1X6.3358Y2.1557Z-0.0305
G1X6.3283Y2.1389Z-0.0328
G1X6.3223Y2.1190Z-0.0355
G1X6.3206Y2.1109Z-0.0366
G1X6.2989Y2.0841Z-0.0219
G1X6.2829Y2.0618Z-0.0088
G1X6.3480Y2.0933Z-0.0088
G1X6.3253Y2.1300Z-0.0340
G1X6.3330Y2.1501Z-0.0312
G1X6.3404Y2.1640Z-0.0292
G1X6.3510Y2.1789Z-0.0271
G1X6.3639Y2.1930Z-0.0249
G1X6.3792Y2.2059Z-0.0228
G1X6.3952Y2.2164Z-0.0209
G1X6.4085Y2.2236Z-0.0199
G1X6.4980Y2.0315Z-0.0443
G1X6.4944Y2.0190Z-0.0432
G1X6.4815Y1.9560Z-0.0428
G1X6.4724Y1.9225Z-0.0405
G1X6.4657Y1.9037Z-0.0381
G1X6.4583Y1.8867Z-0.0348
G1X6.4480Y1.8680Z-0.0302
G1X6.4339Y1.8474Z-0.0246
G1X6.4223Y1.8339Z-0.0211
G1X6.4153Y1.8273Z-0.0198
G1X6.4084Y1.8218Z-0.0193
G1X6.4010Y1.8166Z-0.0195
G1X6.3949Y1.8104Z-0.0223
G1X6.3883Y1.7981Z-0.0316
G1X6.3853Y1.7899Z-0.0387
G1X6.3635Y1.7883Z-0.0362
G1X6.3430Y1.7881Z-0.0351
G1X6.3319Y1.8142Z-0.0088
G1X6.2822Y1.7643Z-0.0088
G1X6.3655Y1.7884Z-0.0363
G1X6.3963Y1.7857Z-0.0349
G1X6.4074Y1.7840Z-0.0337
G1X6.5892Y1.7769Z-0.0338
G1X6.6056Y1.7777Z-0.0326
G1X6.6218Y1.7806Z-0.0306
G1X6.6357Y1.7848Z-0.0283
G1X6.6497Y1.7905Z-0.0259
G1X6.6632Y1.7973Z-0.0235
G1X6.6787Y1.8069Z-0.0209
G1X6.6924Y1.8169Z-0.0187
G1X6.7015Y1.8119Z-0.0088
G1X6.7068Y1.8387Z-0.0088
G1X6.6749Y1.8044Z-0.0214
G1X6.6619Y1.7966Z-0.0237
G1X6.6483Y1.7898Z-0.0262
G1X6.6340Y1.7842Z-0.0286
G1X6.6191Y1.7800Z-0.0309
G1X6.6039Y1.7775Z-0.0328
G1X6.4073Y1.7840Z-0.0337
G1X6.4022Y1.8175Z-0.0193
G1X6.4097Y1.8227Z-0.0193
G1X6.4166Y1.8285Z-0.0199
G1X6.4251Y1.8369Z-0.0219
G1X6.4374Y1.8521Z-0.0258
G1X6.4517Y1.8743Z-0.0318
G1X6.4623Y1.8952Z-0.0366
G1X6.4691Y1.9128Z-0.0394
G1X6.4755Y1.9331Z-0.0415
G1X6.4944Y2.0192Z-0.0432
G1X6.5173Y2.0276Z-0.0274
G1X6.5214Y2.0267Z-0.0245
G1X6.5281Y2.0254Z-0.0217
G1X6.5331Y2.0249Z-0.0212
G1X6.5626Y2.0246Z-0.0215
G1X6.6423Y2.0204Z-0.0257
G1X6.6485Y2.0028Z-0.0088
G1X6.6827Y2.0373Z-0.0088
G1X6.5103Y2.0290Z-0.0330
“M3”
G0Z0.2000
“M3”
G0X7.0392Y1.9519
G1Z-0.0447F10.0
G1X7.0296Y1.9634Z-0.0447F60.0
G1X7.0168Y1.9766Z-0.0445
G1X6.9422Y2.0427Z-0.0439
G1X6.9148Y2.0689Z-0.0443
G1X6.9029Y2.0819Z-0.0446
G1X6.8951Y2.0923Z-0.0444
G1X6.8900Y2.1040Z-0.0429
G1X6.8859Y2.1198Z-0.0402
G1X6.8845Y2.1320Z-0.0382
G1X6.8844Y2.1440Z-0.0361
G1X6.8861Y2.1586Z-0.0334
G1X6.8889Y2.1701Z-0.0313
G1X6.8928Y2.1809Z-0.0293
G1X6.8986Y2.1927Z-0.0272
G1X6.9084Y2.2074Z-0.0245
G1X6.9168Y2.2170Z-0.0232
G1X6.9314Y2.2302Z-0.0216
G1X6.9414Y2.2373Z-0.0210
G1X6.9550Y2.2450Z-0.0206
G1X6.9699Y2.2513Z-0.0204
G1X6.9846Y2.2555Z-0.0207
G1X7.0020Y2.2585Z-0.0212
G1X7.0245Y2.2596Z-0.0222
G1X7.0447Y2.2583Z-0.0235
G1X7.0642Y2.2543Z-0.0249
G1X7.0827Y2.2478Z-0.0272
G1X7.0936Y2.2427Z-0.0292
G1X7.1091Y2.2333Z-0.0330
G1X7.1138Y2.2299Z-0.0345
G1X7.1171Y2.2120Z-0.0278
G1X7.1183Y2.1932Z-0.0229
G1X7.1171Y2.1727Z-0.0201
G1X7.1053Y2.1614Z-0.0088
G1X7.1264Y2.1614Z-0.0088
G1X7.1182Y2.1856Z-0.0216
G1X7.1178Y2.2045Z-0.0256
G1X7.1155Y2.2220Z-0.0313
G1X7.1432Y2.2456Z-0.0088
G1X7.1006Y2.2388Z-0.0307
G1X7.0844Y2.2471Z-0.0275
G1X7.0655Y2.2539Z-0.0251
G1X7.0457Y2.2582Z-0.0235
G1X7.0339Y2.2594Z-0.0228
G1X7.0126Y2.2594Z-0.0216
G1X7.0004Y2.2584Z-0.0212
G1X6.9802Y2.2544Z-0.0205
G1X6.9689Y2.2509Z-0.0204
G1X6.9403Y2.2365Z-0.0211
G1X6.9286Y2.2279Z-0.0219
G1X6.9154Y2.2156Z-0.0233
G1X6.9066Y2.2050Z-0.0250
G1X6.8976Y2.1909Z-0.0274
G1X6.8919Y2.1788Z-0.0297
G1X6.8882Y2.1678Z-0.0318
G1X6.8856Y2.1555Z-0.0341
G1X6.8843Y2.1385Z-0.0369
G1X6.8857Y2.1212Z-0.0399
G1X6.9431Y2.0419Z-0.0439
G1X7.0181Y1.9754Z-0.0446
G1X7.0312Y1.9615Z-0.0446
G1X7.0424Y1.9475Z-0.0445
G1X7.0522Y1.9321Z-0.0441
G1X7.0570Y1.9216Z-0.0433
G1X7.0606Y1.9088Z-0.0416
G1X7.0620Y1.8971Z-0.0395
G1X7.0621Y1.8851Z-0.0372
G1X7.0604Y1.8724Z-0.0348
G1X7.0573Y1.8603Z-0.0323
G1X7.0525Y1.8477Z-0.0296
G1X7.0455Y1.8345Z-0.0266
G1X7.0354Y1.8203Z-0.0235
G1X7.0240Y1.8082Z-0.0213
G1X7.0099Y1.7965Z-0.0196
G1X6.9942Y1.7866Z-0.0187
G1X6.9756Y1.7782Z-0.0186
G1X6.9604Y1.7734Z-0.0192
G1X6.9418Y1.7696Z-0.0203
G1X6.9231Y1.7678Z-0.0220
G1X6.9036Y1.7677Z-0.0239
G1X6.8835Y1.7693Z-0.0262
G1X6.8586Y1.7738Z-0.0293
G1X6.8381Y1.7796Z-0.0323
G1X6.8192Y1.7868Z-0.0351
G1X6.8055Y1.7932Z-0.0372
G1X6.8024Y1.8307Z-0.0088
G1X6.7762Y1.7867Z-0.0208
G1X6.7558Y1.7831Z-0.0088
G1X6.7949Y1.7907Z-0.0315
G1X6.8248Y1.7845Z-0.0343
G1X6.8399Y1.7790Z-0.0320
G1X6.9427Y1.7697Z-0.0203
G1X6.9643Y1.7745Z-0.0189
G1X6.9779Y1.7790Z-0.0186
G1X6.9951Y1.7871Z-0.0187
G1X7.0122Y1.7982Z-0.0197
G1X7.0365Y1.8216Z-0.0237
G1X7.0539Y1.8511Z-0.0302
G1X7.0580Y1.8625Z-0.0327
G1X7.0610Y1.8759Z-0.0354
G1X7.0622Y1.8909Z-0.0382
G1X7.0610Y1.9063Z-0.0411
G1X7.0584Y1.9177Z-0.0429
G1X7.0392Y1.9519Z-0.0447
“M3”
G0Z0.2000
“M3”
G0X7.4967Y2.2233
G1Z-0.0461F10.0
G1Y2.2180Z-0.0447F60.0
G1X7.4953Y2.2043Z-0.0433
G1X7.4516Y1.9845Z-0.0432
G1X7.4425Y1.9438Z-0.0422
G1X7.4360Y1.9213Z-0.0405
G1X7.4279Y1.8989Z-0.0375
G1X7.4213Y1.8848Z-0.0350
G1X7.4110Y1.8661Z-0.0304
G1X7.3971Y1.8459Z-0.0249
G1X7.3842Y1.8311Z-0.0208
G1X7.3716Y1.8198Z-0.0187
G1X7.3646Y1.8144Z-0.0187
G1X7.3587Y1.8067Z-0.0224
G1X7.3536Y1.7938Z-0.0324
G1X7.3520Y1.7883Z-0.0371
G1X7.3324Y1.7867Z-0.0347
G1X7.3187Y1.7867Z-0.0341
G1X7.3041Y1.7872Z-0.0340
G1X7.2978Y1.8039Z-0.0178
G1X7.2951Y1.8139Z-0.0088
G1X7.2996Y1.7984Z-0.0230
G1X7.2455Y1.7643Z-0.0088
G1X7.3298Y1.7866Z-0.0345
G1X7.3439Y1.7874Z-0.0359
G1X7.3521Y1.7883Z-0.0371
G1X7.3577Y1.7862Z-0.0352
G1X7.3717Y1.7837Z-0.0333
G1X7.4446Y1.7815Z-0.0340
G1X7.4551Y1.7559Z-0.0088
G1X7.5017Y1.8055Z-0.0088
G1X7.3713Y1.7838Z-0.0333
G1X7.4291Y1.9019Z-0.0380
G1X7.4967Y2.2180Z-0.0447
G1Y2.2233Z-0.0461
G1X7.5070Y2.2296Z-0.0399
G1X7.5143Y2.2327Z-0.0367
G1X7.5194Y2.2343Z-0.0352
G1X7.5319Y2.2358Z-0.0336
G1X7.5887Y2.2363Z-0.0332
G1X7.6227Y2.2387Z-0.0314
G1X7.6409Y2.2410Z-0.0298
G1X7.6703Y2.2466Z-0.0262
G1X7.6983Y2.2545Z-0.0223
G1X7.7118Y2.2597Z-0.0205
G1X7.7280Y2.2681Z-0.0190
G1X7.7368Y2.2743Z-0.0189
G1X7.7442Y2.2806Z-0.0193
G1X7.7537Y2.2905Z-0.0206
G1X7.7644Y2.3049Z-0.0230
G1X7.7716Y2.3177Z-0.0254
G1X7.7833Y2.3272Z-0.0210
G1X7.7957Y2.3382Z-0.0155
G1X7.8082Y2.3505Z-0.0088
G1X7.7579Y2.3301Z-0.0088
G1X7.7634Y2.3034Z-0.0228
G1X7.7420Y2.2785Z-0.0192
G1X7.7289Y2.2686Z-0.0190
G1X7.7191Y2.2632Z-0.0196
G1X7.7096Y2.2588Z-0.0207
G1X7.6944Y2.2532Z-0.0229
G1X7.6694Y2.2464Z-0.0263
G1X7.5882Y2.2363Z-0.0332
G1X7.4967Y2.2233Z-0.0461
G1X7.4863Y2.2296Z-0.0399
G1X7.4791Y2.2327Z-0.0367
G1X7.4739Y2.2343Z-0.0352
G1X7.4614Y2.2358Z-0.0336
G1X7.4212Y2.2354Z-0.0332
G1X7.3975Y2.2341Z-0.0319
G1X7.3747Y2.2320Z-0.0298
G1X7.3526Y2.2286Z-0.0274
G1X7.3293Y2.2228Z-0.0245
G1X7.3108Y2.2161Z-0.0225
G1X7.2913Y2.2066Z-0.0207
G1X7.2820Y2.2007Z-0.0200
G1X7.2724Y2.1937Z-0.0198
G1X7.2638Y2.1860Z-0.0199
G1X7.2558Y2.1777Z-0.0206
G1X7.2447Y2.1627Z-0.0226
G1X7.2348Y2.1444Z-0.0258
G1X7.2272Y2.1241Z-0.0298
G1X7.2225Y2.1050Z-0.0340
G1X7.2211Y2.0954Z-0.0359
G1X7.2128Y2.0865Z-0.0313
G1X7.1972Y2.0680Z-0.0211
G1X7.1807Y2.0467Z-0.0088
G1X7.2505Y2.0792Z-0.0088
G1X7.2236Y2.1100Z-0.0327
G1X7.2274Y2.1250Z-0.0296
G1X7.2648Y2.1870Z-0.0198
G1X7.2735Y2.1946Z-0.0198
G1X7.2830Y2.2014Z-0.0200
G1X7.2933Y2.2077Z-0.0208
G1X7.3313Y2.2234Z-0.0248
G1X7.3766Y2.2322Z-0.0300
“M3”
G0Z0.2000
“M3”
G0X7.7138Y1.8142
G1Z-0.0501F10.0
G1X7.7723Y1.8064Z-0.0088F60.0
G1X7.7138Y1.8142Z-0.0501
G1X7.7133Y1.8148Z-0.0501
G1X7.7214Y1.8716Z-0.0088
G1X7.6556Y1.8241Z-0.0088
G1X7.7049Y1.7559Z-0.0088
“M3”
G0Z0.2000
“M3”
G0X8.4922Y2.0967
G1Z-0.0503F10.0
G1X8.4911Y2.0813Z-0.0498F60.0
G1X8.4884Y2.0690Z-0.0486
G1X8.4831Y2.0554Z-0.0468
G1X8.4764Y2.0432Z-0.0446
G1X8.4701Y2.0339Z-0.0425
G1X8.4572Y2.0183Z-0.0387
G1X8.4427Y2.0033Z-0.0352
G1X8.4266Y1.9883Z-0.0322
G1X8.4088Y1.9733Z-0.0295
G1X8.3892Y1.9580Z-0.0271
G1X8.3617Y1.9378Z-0.0248
G1X8.3193Y1.9093Z-0.0223
G1X8.2628Y1.8739Z-0.0208
G1X8.1981Y1.8357Z-0.0209
G1X8.1920Y1.8296Z-0.0234
G1X8.1893Y1.8252Z-0.0259
G1X8.1861Y1.8178Z-0.0309
G1X8.1831Y1.8047Z-0.0409
G1X8.1566Y1.8269Z-0.0088
G1X8.1844Y1.7994Z-0.0439
G1X8.1355Y1.7643Z-0.0088
G1X8.1908Y1.7975Z-0.0420
G1X8.2063Y1.7956Z-0.0401
G1X8.4558
G1X8.4771Y1.7643Z-0.0088
G1X8.4558Y1.7956Z-0.0401
G1X8.5017Y1.8269Z-0.0088
G1X8.2063
G1X8.1983Y1.8359Z-0.0209
G1X8.2631Y1.8741Z-0.0208
G1X8.3197Y1.9095Z-0.0223
G1X8.3900Y1.9586Z-0.0272
G1X8.4135Y1.9772Z-0.0302
G1X8.4335Y1.9946Z-0.0335
G1X8.4496Y2.0103Z-0.0369
G1X8.4620Y2.0238Z-0.0401
G1X8.4725Y2.0373Z-0.0432
G1X8.4812Y2.0514Z-0.0461
G1X8.4877Y2.0667Z-0.0485
G1X8.4900Y2.0751Z-0.0493
G1X8.4921Y2.0901Z-0.0501
G1X8.4919Y2.1032Z-0.0503
G1X8.4896Y2.1146Z-0.0495
G1X8.4848Y2.1260Z-0.0473
G1X8.4757Y2.1394Z-0.0434
G1X8.4656Y2.1502Z-0.0395
G1X8.4525Y2.1608Z-0.0349
G1X8.4357Y2.1709Z-0.0302
G1X8.4219Y2.1770Z-0.0269
G1X8.4029Y2.1827Z-0.0235
G1X8.3839Y2.1858Z-0.0214
G1X8.3644Y2.1866Z-0.0206
G1X8.3404Y2.1850Z-0.0205
G1X8.3180Y2.1814Z-0.0215
G1X8.2968Y2.1757Z-0.0237
G1X8.2760Y2.1678Z-0.0277
G1X8.2561Y2.1574Z-0.0333
G1X8.2341Y2.1775Z-0.0088
G1X8.2468Y2.1351Z-0.0270
G1X8.2398Y2.1135Z-0.0231
G1X8.2365Y2.1006Z-0.0215
G1X8.2220Y2.0879Z-0.0088
G1X8.2458Y2.0879Z-0.0088
G1X8.2431Y2.1244Z-0.0248
G1X8.2517Y2.1476Z-0.0303
G1X8.3412Y2.1851Z-0.0205
G1X8.3653Y2.1866Z-0.0206
G1X8.3851Y2.1857Z-0.0215
G1X8.4044Y2.1824Z-0.0237
G1X8.4236Y2.1763Z-0.0273
G1X8.4410Y2.1680Z-0.0316
G1X8.4571Y2.1574Z-0.0365
G1X8.4703Y2.1456Z-0.0412
G1X8.4786Y2.1358Z-0.0446
G1X8.4860Y2.1237Z-0.0480
G1X8.4899Y2.1137Z-0.0496
G1X8.4919Y2.1026Z-0.0503
G1X8.4922Y2.0967Z-0.0503
“M3”
G0Z0.2000
“M3”
G0X9.0202Y1.9826
G1Z-0.0493F10.0
G1X9.0234Y2.0061Z-0.0491F60.0
G1X9.0252Y2.0320Z-0.0483
G1X9.0247Y2.0579Z-0.0470
G1X9.0227Y2.0761Z-0.0456
G1X9.0198Y2.0899Z-0.0440
G1X9.0152Y2.1046Z-0.0419
G1X9.0093Y2.1181Z-0.0394
G1X9.0024Y2.1304Z-0.0368
G1X8.9913Y2.1451Z-0.0333
G1X8.9817Y2.1549Z-0.0307
G1X8.9684Y2.1652Z-0.0276
G1X8.9562Y2.1723Z-0.0254
G1X8.9432Y2.1779Z-0.0237
G1X8.9247Y2.1831Z-0.0220
G1X8.9096Y2.1855Z-0.0212
G1X8.8862Y2.1866Z-0.0207
G1X8.8661Y2.1854Z-0.0209
G1X8.8470Y2.1819Z-0.0216
G1X8.8282Y2.1761Z-0.0229
G1X8.8097Y2.1680Z-0.0248
G1X8.7911Y2.1569Z-0.0273
G1X8.7731Y2.1430Z-0.0302
G1X8.7565Y2.1270Z-0.0331
G1X8.7406Y2.1083Z-0.0363
G1X8.7256Y2.0870Z-0.0394
G1X8.7122Y2.0638Z-0.0424
G1X8.7004Y2.0376Z-0.0452
G1X8.6917Y2.0120Z-0.0470
G1X8.6848Y1.9837Z-0.0483
G1X8.6805Y1.9539Z-0.0487
G1X8.6786Y1.9229Z-0.0483
G1X8.6787Y1.9079Z-0.0478
G1X8.6797Y1.8905Z-0.0465
G1X8.6818Y1.8747Z-0.0448
G1X8.6852Y1.8597Z-0.0429
G1X8.6913Y1.8418Z-0.0401
G1X8.6968Y1.8303Z-0.0378
G1X8.7037Y1.8189Z-0.0352
G1X8.7119Y1.8081Z-0.0326
G1X8.7215Y1.7982Z-0.0301
G1X8.7352Y1.7874Z-0.0270
G1X8.7470Y1.7805Z-0.0250
G1X8.7591Y1.7752Z-0.0235
G1X8.7747Y1.7706Z-0.0222
G1X8.7918Y1.7676Z-0.0212
G1X8.8155Y1.7665Z-0.0207
G1X8.8353Y1.7677Z-0.0208
G1X8.8499Y1.7698Z-0.0209
G1X8.8707Y1.7750Z-0.0218
G1X8.8818Y1.7788Z-0.0225
G1X8.8965Y1.7855Z-0.0237
G1X8.9126Y1.7950Z-0.0258
G1X8.9248Y1.8039Z-0.0275
G1X8.9396Y1.8170Z-0.0304
G1X8.9555Y1.8346Z-0.0339
G1X8.9719Y1.8573Z-0.0382
G1X8.9826Y1.8750Z-0.0413
G1X8.9931Y1.8958Z-0.0444
G1X9.0036Y1.9207Z-0.0469
G1X9.0127Y1.9487Z-0.0487
G1X9.0180Y1.9710Z-0.0493
G1X9.0202Y1.9826Z-0.0493
“M3”
G0Z0.2000
G1Z-0.0493F10.0
G1X9.0141Y1.9541Z-0.0488F60.0
G1X9.0059Y1.9272Z-0.0475
G1X8.9978Y1.9062Z-0.0456
G1X8.9881Y1.8854Z-0.0429
G1X8.9726Y1.8584Z-0.0384
G1X8.9629Y1.8442Z-0.0358
G1X8.9467Y1.8244Z-0.0318
G1X8.9310Y1.8091Z-0.0288
G1X8.9220Y1.8017Z-0.0272
G1X8.9092Y1.7928Z-0.0252
G1X8.8925Y1.7836Z-0.0234
G1X8.8800Y1.7781Z-0.0223
G1X8.8592Y1.7718Z-0.0213
G1X8.8474Y1.7693Z-0.0209
G1X8.8319Y1.7673Z-0.0206
G1X8.8101Y1.7665Z-0.0208
G1X8.7894Y1.7680Z-0.0213
G1X8.7573Y1.7759Z-0.0237
G1X8.7450Y1.7815Z-0.0254
G1X8.7325Y1.7892Z-0.0276
G1X8.7101Y1.8103Z-0.0331
G1X8.7010Y1.8232Z-0.0361
G1X8.6944Y1.8351Z-0.0386
G1X8.6889Y1.8480Z-0.0410
G1X8.6835Y1.8661Z-0.0439
G1X8.6810Y1.8791Z-0.0454
G1X8.6794Y1.8930Z-0.0467
G1X8.6787Y1.9249Z-0.0483
G1X8.6808Y1.9562Z-0.0487
G1X8.6853Y1.9861Z-0.0482
G1X8.6924Y2.0145Z-0.0469
G1X8.7018Y2.0412Z-0.0448
G1X8.7134Y2.0661Z-0.0422
G1X8.7269Y2.0891Z-0.0391
G1X8.7421Y2.1102Z-0.0359
G1X8.7584Y2.1290Z-0.0327
G1X8.7750Y2.1446Z-0.0298
G1X8.7926Y2.1579Z-0.0270
G1X8.8107Y2.1685Z-0.0247
G1X8.8292Y2.1765Z-0.0228
G1X8.8479Y2.1821Z-0.0215
G1X8.8672Y2.1855Z-0.0208
G1X8.8871Y2.1866Z-0.0207
G1X8.9115Y2.1853Z-0.0213
G1X8.9271Y2.1826Z-0.0222
G1X8.9581Y2.1713Z-0.0257
G1X8.9705Y2.1638Z-0.0281
G1X9.0106Y2.1156Z-0.0399
G1X9.0166Y2.1009Z-0.0425
G1X9.0203Y2.0876Z-0.0443
G1X9.0232Y2.0721Z-0.0459
G1X9.0248Y2.0560Z-0.0471
G1X9.0221Y1.9944Z-0.0492
“M3”
G0Z0.2000
“M3”
G0X9.3270Y2.1470
G1Z-0.0528F10.0
G1X9.3845Y2.1986Z-0.0088F60.0
G1X9.3270Y2.1470Z-0.0528
G1X9.3177Y2.1524Z-0.0462
G1X9.3030Y2.1592Z-0.0376
G1X9.2911Y2.1629Z-0.0325
G1X9.2780Y2.1651Z-0.0286
G1X9.2610Y2.1661Z-0.0255
G1X9.2284Y2.1655Z-0.0220
G1X9.2150Y2.1771Z-0.0088
G1X9.2154Y2.1532Z-0.0088
G1X9.2624Y2.1661Z-0.0257
G1X9.2810Y2.1648Z-0.0294
G1X9.2960Y2.1615Z-0.0344
G1X9.3075Y2.1574Z-0.0400
G1X9.3267Y2.1349Z-0.0503
G1X9.3242Y2.1157Z-0.0483
G1X9.3174Y2.0807Z-0.0469
G1X9.2723Y1.8526Z-0.0472
G1X9.2691Y1.8370Z-0.0476
G1X9.2640Y1.8112Z-0.0495
G1X9.2634Y1.8060Z-0.0505
G1X9.2427Y1.7917Z-0.0362
G1X9.2301Y1.7849Z-0.0294
G1X9.2185Y1.7807Z-0.0252
G1X9.2040Y1.7779Z-0.0224
G1X9.1876Y1.7766Z-0.0211
G1X9.1512Y1.7762Z-0.0207
G1X9.1434Y1.7882Z-0.0088
G1X9.1329Y1.7643Z-0.0088
G1X9.1891Y1.7767Z-0.0212
G1X9.2093Y1.7787Z-0.0232
G1X9.2226Y1.7820Z-0.0265
G1X9.2350Y1.7873Z-0.0318
G1X9.2517Y1.7976Z-0.0422
G1X9.2790Y1.7933Z-0.0378
G1X9.2907Y1.7862Z-0.0307
G1X9.3011Y1.7817Z-0.0262
G1X9.3133Y1.7783Z-0.0228
G1X9.3284Y1.7765Z-0.0210
G1X9.3618Y1.7762Z-0.0207
G1X9.3743Y1.7643Z-0.0088
G1X9.3731Y1.7882Z-0.0088
G1X9.2653Y1.8188Z-0.0486
G1X9.2696Y1.8394Z-0.0475
G1X9.2869Y1.9262Z-0.0467
G1X9.3176Y2.0821Z-0.0469
G1X9.3246Y2.1183Z-0.0485
“M3”
G0Z0.2000
“M3”
G0X9.5672Y1.9956
G1Z-0.0547F10.0
G1X9.5629Y1.9738Z-0.0525F60.0
G1X9.5601Y1.9492Z-0.0507
G1X9.5595Y1.9300Z-0.0494
G1X9.5602Y1.9122Z-0.0483
G1X9.5621Y1.8956Z-0.0472
G1X9.5650Y1.8802Z-0.0460
G1X9.5691Y1.8651Z-0.0447
G1X9.5748Y1.8501Z-0.0430
G1X9.5818Y1.8359Z-0.0412
G1X9.5901Y1.8229Z-0.0392
G1X9.5994Y1.8110Z-0.0371
G1X9.6099Y1.8004Z-0.0347
G1X9.6248Y1.7886Z-0.0316
G1X9.6372Y1.7812Z-0.0290
G1X9.6511Y1.7751Z-0.0264
G1X9.6694Y1.7698Z-0.0234
G1X9.6837Y1.7676Z-0.0219
G1X9.7042Y1.7670Z-0.0202
G1X9.7241Y1.7694Z-0.0194
G1X9.7348Y1.7721Z-0.0191
G1X9.7481Y1.7766Z-0.0193
G1X9.7616Y1.7828Z-0.0201
G1X9.7789Y1.7938Z-0.0216
G1X9.7951Y1.8071Z-0.0236
G1X9.8107Y1.8230Z-0.0259
G1X9.8245Y1.8404Z-0.0285
G1X9.8369Y1.8593Z-0.0314
G1X9.8471Y1.8783Z-0.0343
G1X9.8571Y1.9030Z-0.0376
G1X9.8627Y1.9220Z-0.0400
G1X9.8667Y1.9418Z-0.0421
G1X9.8690Y1.9622Z-0.0438
G1X9.8697Y1.9788Z-0.0449
G1X9.8693Y1.9949Z-0.0458
G1X9.8672Y2.0124Z-0.0463
G1X9.8627Y2.0296Z-0.0460
G1X9.8591Y2.0388Z-0.0453
G1X9.8514Y2.0532Z-0.0438
G1X9.8445Y2.0628Z-0.0422
G1X9.8332Y2.0749Z-0.0401
G1X9.8252Y2.0815Z-0.0384
G1X9.8142Y2.0883Z-0.0364
G1X9.8005Y2.0944Z-0.0340
G1X9.7902Y2.0975Z-0.0323
G1X9.7788Y2.0997Z-0.0306
G1X9.7670Y2.1009Z-0.0289
G1X9.7479Y2.1004Z-0.0266
G1X9.7260Y2.0969Z-0.0239
G1X9.7109Y2.0924Z-0.0220
G1X9.6949Y2.0858Z-0.0203
G1X9.6832Y2.0796Z-0.0192
G1X9.6705Y2.0712Z-0.0182
G1X9.6530Y2.0570Z-0.0175
G1X9.6430Y2.0473Z-0.0174
G1X9.6333Y2.0367Z-0.0174
G1X9.6239Y2.0250Z-0.0178
G1X9.6147Y2.0122Z-0.0185
G1X9.6099Y2.0069Z-0.0204
G1X9.6066Y2.0047Z-0.0222
G1X9.5988Y2.0013Z-0.0276
G1X9.5845Y1.9975Z-0.0394
G1X9.5672Y1.9956Z-0.0547
G1X9.5657Y2.0114Z-0.0507
G1X9.5674Y2.0266Z-0.0493
G1X9.5738Y2.0564Z-0.0474
G1X9.5827Y2.0857Z-0.0452
G1X9.5908Y2.1068Z-0.0432
G1X9.6026Y2.1320Z-0.0407
G1X9.6172Y2.1579Z-0.0381
G1X9.6310Y2.1786Z-0.0358
G1X9.6473Y2.2002Z-0.0335
G1X9.6693Y2.2246Z-0.0309
G1X9.6840Y2.2389Z-0.0290
G1X9.7046Y2.2559Z-0.0269
G1X9.7223Y2.2680Z-0.0252
G1X9.7429Y2.2795Z-0.0237
G1X9.7607Y2.2872Z-0.0227
G1X9.7803Y2.2935Z-0.0221
G1X9.8002Y2.2975Z-0.0222
G1X9.8207Y2.2994Z-0.0228
G1X9.8434Y2.2990Z-0.0242
G1X9.8585Y2.2973Z-0.0253
G1X9.8776Y2.2927Z-0.0276
G1X9.8935Y2.2866Z-0.0303
G1X9.9079Y2.2791Z-0.0338
G1X9.9154Y2.2742Z-0.0361
G1X9.9176Y2.2606Z-0.0304
G1X9.9186Y2.2433Z-0.0250
G1X9.9173Y2.2274Z-0.0221
G1X9.9163Y2.2211Z-0.0215
G1X9.9017Y2.2084Z-0.0088
G1X9.9260Y2.2084Z-0.0088
G1X9.9183Y2.2372Z-0.0237
G1X9.9184Y2.2517Z-0.0274
G1X9.9172Y2.2637Z-0.0316
G1X9.9483Y2.2913Z-0.0088
G1X9.8999Y2.2836Z-0.0317
G1X9.8833Y2.2907Z-0.0284
G1X9.8661Y2.2958Z-0.0261
G1X9.8547Y2.2978Z-0.0251
G1X9.8385Y2.2994Z-0.0237
G1X9.8134Y2.2990Z-0.0226
G1X9.7987Y2.2973Z-0.0222
G1X9.7795Y2.2932Z-0.0222
G1X9.7599Y2.2869Z-0.0227
G1X9.7401Y2.2781Z-0.0238
G1X9.7170Y2.2646Z-0.0258
G1X9.7017Y2.2537Z-0.0271
G1X9.6808Y2.2359Z-0.0295
G1X9.6641Y2.2192Z-0.0314
G1X9.6462Y2.1987Z-0.0336
G1X9.6265Y2.1721Z-0.0366
G1X9.6149Y2.1541Z-0.0384
G1X9.6011Y2.1292Z-0.0410
G1X9.5882Y2.1003Z-0.0439
G1X9.5780Y2.0711Z-0.0464
G1X9.5703Y2.0416Z-0.0485
G1X9.5669Y2.0238Z-0.0494
“M3”
G0Z0.2000
G1Z-0.0547F10.0
G1X9.5845Y1.9975Z-0.0394F60.0
G1X9.6010Y2.0021Z-0.0260
G1X9.6154Y2.0131Z-0.0184
G1X9.6250Y2.0265Z-0.0177
G1X9.6357Y2.0395Z-0.0173
G1X9.6633Y2.0657Z-0.0179
G1X9.6737Y2.0735Z-0.0185
G1X9.6842Y2.0802Z-0.0193
G1X9.6979Y2.0872Z-0.0206
G1X9.7163Y2.0942Z-0.0228
G1X9.7276Y2.0973Z-0.0241
G1X9.7816Y2.0993Z-0.0309
G1X9.7939Y2.0965Z-0.0328
G1X9.8059Y2.0923Z-0.0349
G1X9.8184Y2.0860Z-0.0372
G1X9.8282Y2.0791Z-0.0390
G1X9.8398Y2.0683Z-0.0414
G1X9.8468Y2.0599Z-0.0427
G1X9.8559Y2.0454Z-0.0447
G1X9.8604Y2.0357Z-0.0455
G1X9.8652Y2.0213Z-0.0463
G1X9.8686Y2.0028Z-0.0462
G1X9.8695Y1.9925Z-0.0457
G1X9.8696Y1.9728Z-0.0447
G1X9.8683Y1.9537Z-0.0433
G1X9.8655Y1.9348Z-0.0415
G1X9.8612Y1.9160Z-0.0394
G1X9.8551Y1.8972Z-0.0370
G1X9.8097Y1.8220Z-0.0257
G1X9.7612Y1.7826Z-0.0200
G1X9.7433Y1.7747Z-0.0194
G1X9.7334Y1.7717Z-0.0191
G1X9.7197Y1.7687Z-0.0194
G1X9.6667Y1.7704Z-0.0239
G1X9.6212Y1.7911Z-0.0322
G1X9.6080Y1.8021Z-0.0351
G1X9.5950Y1.8162Z-0.0382
G1X9.5869Y1.8274Z-0.0401
G1X9.5798Y1.8395Z-0.0418
G1X9.5737Y1.8527Z-0.0434
G1X9.5683Y1.8679Z-0.0449
G1X9.5643Y1.8838Z-0.0462
G1X9.5615Y1.9003Z-0.0475
G1X9.5599Y1.9179Z-0.0486
G1X9.5596Y1.9380Z-0.0498
G1X9.5617Y1.9650Z-0.0518
G1X9.5640Y1.9806Z-0.0532
“M3”
G0Z0.2000
G0Z0.5000
“M5”
G0X0.0000Y0.0000
M02
I don’t know if I posted that right or not.
Please let me know.
