I’m stuck on the sideline. My X-Carve PRO is playing the “2-year old Child” game… I cannot get the “Carve” button to turn green. Meaning that it will not connect with my computer. And the led does not light up on the controller box.
It had done that for months when I first set it up a year and a half ago. I had to do hard-boots to both the computer AND the X-Carve multiple times EVERY time that I tried to use it. Then mysteriously, it stopped doing that several months later, and I hadn’t had a problem in about a year. Then today, in the midst of making last minute Christmas presents, it flat out refuses to connect. I did a half dozen 'Hard-Boots" to the machine, as well as shut down the computer and brought it back up… NOTHING.
So, a call to Tec Support and the solution was similar to what modern day auto mechanics do “Throw money at it.”
The suggestion is to change out the controller box (the box with the emergency stop button), at $300 bucks. I was told that if that doesn’t work, I should spend a thousand bucks on a new tower. If that doesn’t work, we can take another look at other possibilities.
It seems that “all the possibilities” should be looked at FIRST, but apparently, there is no way to trouble-shoot in Inventables book.
This makes ZERO sense to me. Anyone who has read my posts can see that I am an analog guy trapped in a digital world. But testing electronics IS ANALOG. I own multiple multi-meters and testing equipment. I am capable of testing the controller box (whatever it’s called), but I need to know what I’m looking for. This is apparently outside the wheelhouse of Tec Support.
Thus, my question for the group is; 1) has anyone experienced this? 2) does anyone know what I need to test for? 3) is there a schematic somewhere?
As an FYI, I did the most basic of ‘tests’ which is to say that I opened the controller and bypassed the emergency stop button. This did not resolve the issue, so presumably the problem is not with the kill switch.
Sorry, I’m an old-timer. I don’t belong in this ‘throw-away’ world. I FIX stuff when it breaks, and I don’t just throw money at things and throw away perfectly good parts rather than figuring out what is wrong, I test them to make sure that they are broken first, and THEN buy the parts necessary (including rebuilding that control box rather than replacing the whole thing if it’s just a switch or a plug).
That is what I need to do, but it appears that this is a foreign concept in 2024
Anyone gone through this?
Any suggestions?
