https://discuss-assets.s3.amazonaws.com/original/3X/a/6/a6428dc423ff16c102cf408377ee5f50a168ab68.mp4
https://discuss-assets.s3.amazonaws.com/original/3X/1/6/16b95083ef08c21a76131766a9f2fe7007c9424e.mp4
Hell Yeah. people are waiting on me. they want thing made for car audio. i need mine sent over night to. i have more parts coming in tomorrow. already have my 1800mm rails. smh. i had some many plans for the X-carve.
Yes. everything worked. i was moving it around. then it just stop. never moved or came back on after that.
So instead of inventables givng me a pre-made X-controller. They had me over night ship. my X-controller to them. So they could get down to the Bottom of this problem. Theyāve had multiple calls with the same issue that i was having. from there testing of my X-controller. They replaced the estop cable. It had Bad crimp. So now my X-controller is up and running. and will be over night ship to me. And i should have it here tomorrow.
https://discuss-assets.s3.amazonaws.com/original/3X/b/c/bc69f566c2eb24422dd036899b9d0c88c8f691b9.mp4
My issue with the xcontroller is I can connect with my wifeās pc right away, but canāt with my new laptop I bought for this. Sounds dumb right, sent help desk an email.
that sucks. did you install all the drivers
I followed the page for the setup on her pc, got it working. Bought mine did the same exact thing, nothing happens, motors stepup, xcontroller on, yada yada yada, unplug from mine to hers poof make the machine work again
Does the Xcontroller show up in the Device Manager on yours at all?
Oh boy, I just received my X Controller two days ago (the 5th and final package lol) Sounds like im in for a treat!
yes it does
@NeilFerreri1 the driver wouldnāt download, did it manually, update computer, wait for another restart 2 hrs later itās working, now just have to make this 2 stage carve work
Iāve just assembled my brand new x-carve (1000mm kit) and I am having the same problemā¦ The light is green, the fan is running, I can hear the motors when I turn it on, but nothing, I canāt run the setup on easel (on my MacBook pro), thereās a message saying connecting but nothing happensā¦ Iāve tried to check the e-stop button, bypass it the button, another laptop, another USB cable (also direct on the board), but nothingā¦ It is so frustrating to have a machine without work as it supposed toā¦ I sent a message yesterday to help center but still waiting their answer.
Make sure that you are trying to connect at 115200 baud.
If thatās ok then try installing/updating the FTDI serial port driver.
Thanks LarryM, but I have no idea how to do it on MacOs. Iāve seen that 115200 baud it is something related to the USB speed rate, right? Could you tell me more about it this procedure? Thanks again
Yes it does. I donāt use Macs, so I canāt help there. Maybe someone else can jump in on that one.
Most gcode sender shoulds set the Baud rate correctly by itself afaik. Nevertheless you should be able to set the Baud rate manually in the device manager in Windows for your port (not in my workshop until weekend, so I canāt check now).
Should be something like: open device manager, COM port, right click, properties, then the second tab control (donāt know what itās called in an english windows, should be something like connection settings or anything similar)
