Hey there starting to loose my mind with easel and my xcarve. I feel every time I want to use the machine it’s forgotten my settings.
But when I do get around to cutting it runs fine till the second last pass and just cuts right thru the piece then proceeds to cut the tabs in the right place
I just don’t get why it’s doing this. Luckily its ply board as it would of broken the cutter
check the section on calibration and losing steps/binding
also in the same post… I posted the main things i did to fix this kind of thing when I ran into it. I will be doing more to improve the machine, but just needed to get it going for making some gifts.
Hope this helps!
Thanks @AbearDesign for the response. ill go through the issues on binding. what makes me think its something different is that it happens only at certain height and point
